Old 02-03-2015, 01:43 AM   #1
2005 19' Safari
GLENDALE , AZ
Replacement Stop/Turn/Tail Lights for 2005 Bambi (19')
Today, I installed new LED tail lights on our 2005 19' Bambi; because two of the four OEM assemblies had numerous LEDs that were defective.
After removing one of the old tail lights and taking some measurements, I discovered that the original lights are standard 4" stop/turn/tail lights that are often used on utility and large semi-trailers.
After a little online shopping, I decided to replace them with Optronics GLOLights (STL101RCB), which are a little unusual, but very bright. When not illuminated, these tail lights have a red outside ring and a clear center lens.
When running lights are on, a solid red ring is displayed and the clear center is dark. Then, when brakes are applied or turn signal or hazard lights are selected, the red LEDS in the clear center section are illuminated, in addition to the red outside ring.
When the running lights are off and the brakes are depressed, all LEDs are lit and the whole tail light illuminates red.
These tail lights are widely available, and I purchased them online for about $18 each. Plus, the vendor I selected provided free shipping.
I should note that installation was simple, but not necessarily easy. While these lights are available as a "bracket mount" assembly, I ordered the "grommet mount" lights; because the OEM bracket mount lights had been over-torqued at the factory, and one of the light housings was broken. I figured that the grommet mount lights didn't use any screws; so I wouldn't have to worry about the housings cracking and water getting into the electronics, which I think may have contributed to the failure of some of the LEDs in the OEM units.
In any case, installing the lights (with grommets) into the existing 4.5" holes in the Bambi's skin was a very tight fit and required a lot of poking and prodding. Upon completion, I discovered that the grommets may not be as flat against the aluminum skin of our Bambi as they would probably be on the steel frame of a semi-trailer. However, the overall appearance looks great to me; and it's water-tight.
Name:	zzzBambi Tail Lights_1.JPG
ID:	231611   Click image for larger version
Name:	zzzBambi Tail Lights_2.JPG
Name:	zzzBambi Tail Lights_3.JPG
ID:	231613   Click image for larger version
Name:	zzzBambi Tail Lights_4.JPG
Name:	zzzBambi Tail Lights_5.JPG
Old 02-13-2015, 02:25 AM   #2
2005 19' Safari
GLENDALE , AZ
Reference my original comment, above:
"... installing the lights (with grommets) into the existing 4.5" holes in the Bambi's skin was a very tight fit and required a lot of poking and prodding. Upon completion, I discovered that the grommets may not be as flat against the aluminum skin of our Bambi as they would probably be on the steel frame of a semi-trailer."
After investigating to determine why it was so difficult to insert these lights, I discovered that the Optronics GLOLight is about 1/2 to 3/4" thicker than the depth of the 4.5" hole in which the light is installed; and the connector on the back of the light housing was bottoming out against the inner aluminum skin behind the mounting hole.
After I realized my mistake, I modified these lights by cutting about 1/2" off of the connector shell that protrudes out the back of the light housing, which necessitated the fabrication of a modified, 90-degree, low-profile mating connector for the wiring harness.
After performing these customizations, the grommets were easily inserted fully into the 4.5" hole, and the GLOLights popped right into the grommets.
For others contemplating the replacement of their OEM LED tail lights, please note that Optronics GLOLights and mating connectors will require extensive modification before they can be installed properly.
Consequently, while the result will be an Airstream with very unique tail lights (I suspect I will have the only one in existence, due to the amount of rework required), most will find the exact replacement lights to be a much faster and easier installation.
Old 02-17-2015, 04:02 AM   #3
2005 19' Safari
GLENDALE , AZ
The following photos show Optronics GLOLights BEFORE and AFTER the tail light housing connector and harness were modified. These pictures are posted as a reference for those who may elect to install these unique LED tail lights, despite them requiring modification to achieve a proper fit.
The tail light shown with a gap between the grommet and the aluminum body is improperly installed and not fully inserted.
The other tail light with the grommet compressed flush with the aluminum skin is properly installed.
Name:	zzzBambi Tail Lights_A1.JPG
ID:	232589   Click image for larger version
Name:	zzzBambi Tail Lights_A2.JPG
Name:	zzzBambi Tail Lights_A3.JPG
ID:	232591   Click image for larger version
Name:	zzzBambi Tail Lights_A4.JPG
Name:	zzzBambi Tail Lights_A5.JPG
Old 02-28-2015, 11:29 AM   #4
Dan@LED4RV's Avatar
Denton , North Carolina
Great post
It looks like the tail lights where some of them failed top left picture on first post are Kaper. Kaper is a company that updates their products over time they get better as time goes on with a "Next generation light". I have found that when some of these LEDs fail and you what to replace them the next generation from the same company may have a different LED pattern. Then you have to change all of them to keep it from looking odd. Going with a company like Bargman, allows you to change to a style that will be around a while so that if one fails, you will only have to change the one, and they all still look the same. Optronics has some good products and they show some staying power as a company and they are constantly changing their styles. Phoenix great post here and thanks for sharing what you learn.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 05:05 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
'65 Globetrotter led brake/stop/turn tail light kennyp315 Lights - Interior & Exterior 3 12-06-2008 07:10 AM
4-Inch 10-LED stop turn tail light ($11) COUPON** Wabbiteer Electrical - Systems, Generators, Batteries & Solar 1 07-20-2006 09:27 AM
Stop,Turn,Tail LED PROBLEM Wardinbb Lights - Interior & Exterior 5 09-17-2004 12:52 PM
