Replacement LED fixture under front cap
Our 1988 25' has the original equipment single slider type fixtures for under the front cap above the couch. Has anyone replaced these fixtures with LED fixtures that were bright enough to read by without being too bright and then having to use dimmers to be happy? After reading all the threads here on LEDs it seems that replacement LED bulbs for incandescents are talked about as are LED replacement for halogens. I realize there are many catalogs out there both RV and Marine LEDs but am looking for a recommendation from someone who has done the replacement and is happy with it.
Also-- how about recessed LED fixtures under these older plastic front caps? Is there enough clearance width for them to look right? Does the existing wiring
