Old 02-04-2015, 08:04 AM   #1
richw46's Avatar
Lexington , Kentucky
Replacement interior ceiling light switch
The canopy push switch in my front, underside, storage compartment bin, single bulb fixture, broke. I went to swap it with the one in the storage compartment and found someone had already done this; it was gone.
I was thinking I would have to replace the entire unit but found a switch at Home Depot that worked. I took out the original spring and the new switch fit snugly where the old one was. It's a little tight and while mine doesn't stick now, I might need to add some silicone to let it slide. But it does the trick for $4 each. Thought I'd pass it along.
Gardner Bender
Model # GSW-24
Internet # 100122779
Store SKU # 807109 Gardner Bender
Model # GSW-24
Store SKU # 807109
Gardner Bender 10/8/4 Amp Single-Pole Maintained Contact Push-Button Switch- Nickel plating-GSW-24 - The Home Depot
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 02-04-2015, 08:46 AM   #2
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Thanks. I found a rotary 3 way to replace my ceiling switches at lowes. About $4 each and work like a charm.
NavyCorpsman is offline   Reply With Quote
Ceiling light switch for '74 AS International Razorhog Lights - Interior & Exterior 5 08-30-2013 03:07 PM
Interior Ceiling Light for '63 Safari 63Sfri Lights - Interior & Exterior 1 08-12-2010 11:28 AM
Light Switch (Wall Switch) for 69 Overlander mbmbstreamer Lights - Interior & Exterior 3 03-21-2010 05:39 PM
Plastic light switch for ceiling light in 1979 Sov. Bowmans Lights - Interior & Exterior 4 10-14-2009 06:17 PM
broken ceiling light toggle switch ole81 Lights - Interior & Exterior 5 07-23-2007 04:15 PM
