Old 01-19-2008, 02:15 PM   #1
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Replace Marker / Clearance Lights On '87 Excella
I want to replace the marker / clearance lights on my '87 Excella because the bases are so deteriorated. I was wondering if anybody has any sources for relacements. The original lights are made by signal-stat they are double bulls-eys lenses with two wedge style bulbs. The numbers in the base are 1220/1211 and the number on the lenses are 9006. There is a red lead and a white lead that come out of the trailer body with male bullet connectors on the wires. The leads go through two holes in the light base. There are female bullet connectors on the base of the lights that the trailer leads plug into. The lights DO NOT ground to the trailer
I am having trouble locating replacements. All marker / clearance lights I find are single wire leads that ground to the trialer body.
I have attached a picture of the base and lens
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 01-19-2008, 02:23 PM   #2
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
www.vehiclelight.com has the two wire connection LED bulleye clearance lamps you are looking for.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-19-2008, 02:59 PM   #3
davidz71's Avatar
1986 25' Sovereign
Check out this thread: http://www.airforums.com/forums/f447...hts-34414.html
Craig
AIR #0078
3.73 rear end
Old 01-19-2008, 03:34 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
You can get them thru Airstream. They have the LED and originals. The only place I've found them that include a gasket.
Old 01-19-2008, 08:02 PM   #5
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Check out this thread.
Mine didn't come with gaskets but I used a syringe with Trempro (vulkem) to seal them off.
$1.99 ea seemed fair to me. L.E.D.s will run a bit more.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 01-19-2008, 08:08 PM   #6
azfiredog300's Avatar
Surprise , Arizona
Hey Pizzachop, has #8 made dry dock yet?
azfiredog300 is offline   Reply With Quote
Old 01-19-2008, 08:51 PM   #7
PizzaChop's Avatar
1973 31' Sovereign
Images: 202
Firedog,
Take a look here and here .
We did decide on Charles for a middle name.
Ron Kaes
Psalm 112
www.paparonnis.com
Old 01-19-2008, 09:02 PM   #8
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Clearance light project
I replaced my old clearance lights with L.E.D's made by Grote - actually found something domestically made.
Here are a couple of photos.
This is a picture of the old light.
The second picture shows where I had to drill a small hole through the light body to thread the ground wire through to the front. LED's will have both a ground and power wire.
The third picture shows the hole in the lower right hand corner.
The fourth picture shows a the connector soldered onto the ground wire. This will be placed behind the mounting screw.
The fifth picture shows the power wire soldered together with heat shrink ready to go over the joint.
The last picture shows the finished product - just need to add the lense. I did put caulking on the rear of the light body and in the screw holes before the light was mounted. Let me tell you these are cool looking at night. My neighbors all remarked that my trailer in the driveway looked like a Christmas Tree with all the new lights.
crispyboy is offline   Reply With Quote
Old 01-19-2008, 09:05 PM   #9
Kajtek1's Avatar
1965 22' Safari
Orinda , California
That type of marker lights are available at any Truck Stop. Last time I paid about $3.50, but with the inflation rate it might be over $5 now.
Personally I don't like the look of LED lights. They make sense technically, but are ugly like hybrids.
Even my trailer come originally equipped with the same type lights the original poster has - I just bought those on ebay.
Kajtek1 is offline   Reply With Quote
Old 01-20-2008, 06:45 AM   #10
DEITZ645's Avatar
Thanks for all the replies. I have attached some more pictures of what the wiring looks like coming out of the trailer and how the wiring mounts onto the light. My problem is that the replies all seem to have trailer lights that ground through one of the mounting screws. Mine DO NOT ground through the mounting screws. And there lies the dilemma. All replacements I have found so far ground through the mounting screws. I am hesitant to purchase an LED light too because I think I will be in the same boat. Does anybody know how my wiring set up works? Is the red wire a hot lead? Is the white wire a common lead? If I canít find a replacement for these darn lights, I am going to be up the proverbial creek.
ID:	52793   Click image for larger version
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 01-20-2008, 07:41 AM   #11
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The last lights I got like that, I got from Wal-Mart for $1.97 each. The new ones don't need the ground wire, they will ground through one of the mounting screws. Just make sure you use fresh screws.
Old 01-20-2008, 09:38 AM   #12
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Add a ground wire?
Can you add a ground wire and isolate the ground from the trailer?
You could also try SUPER BRIGHT LEDS home I replaced all my running ligths with LEDs
Michelle TAC MT-0
Sarah, Snowball
Old 01-20-2008, 12:16 PM   #13
PizzaChop's Avatar
1973 31' Sovereign
Images: 202
Wow, those are different!
Not a big deal though, just cut off the bullet end on the ground wire and crimp an "eye" to it. Then you can pass the screw or rivet (however you choose to attach the base) through it. It'll have two grounds (the wire and the aluminum skin)
If you're not too concerned, just skip the ground wire altogether and trust that the shell will provide the grounding.
Ron Kaes
Psalm 112
www.paparonnis.com
Old 01-20-2008, 12:20 PM   #14
davidz71's Avatar
1986 25' Sovereign
Carl,
The led unit I mentioned before and have pictured below is from Led Truck Lights, Led stop lights, Led clearance lights, led Marker lights, Led trailer lights, truck lights, led strobe lights. You are making this much harder than it really is. All you have to do is crimp on one of those female end connectors to each wire of the light, plug them into the male connector you have in your picture, make sure the wires are not hanging out from the flange at the edge of the light and screw the light back on. I promise you it is that easy. The female connector I used had a plastic cover around it and this keeps the wire from grounding to the aluminum. You could also use shrink insulation as shown by a previous poster. You then run a bead of Trempro, Sikaflex or Vulcum over the top edgeto prevent water from getting behind the light and through the hole in the trailer where the wires enter. Trust me, it was so much easier than the work I had to do with the LEDs-R-US lights.
Craig
AIR #0078
3.73 rear end
Replace '73 Overlander clearance lights? Lothlorian Lights - Interior & Exterior 21 01-21-2008 05:27 PM
Clearance / Marker Lamp Question Number99 Lights - Interior & Exterior 5 01-04-2007 04:52 PM
Running marker / clearance lights unhooked Kistler Electrical - Systems, Generators, Batteries & Solar 19 12-18-2006 07:30 PM
LED Clearance/Marker lights Safari Tim Lights - Interior & Exterior 13 10-24-2003 09:54 PM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
