12-29-2007, 09:44 AM
Loganville
, Georgia
Replace '73 Overlander clearance lights?
Who makes the airstream 73 overlander clearance lights? I was shopping at northern tool and came upon clearance lights that look exactly like mine. The lights I was looking at were made by a company named peterson. Could I use those peterson clearance lights? The orginal lights are in terrible shape.
SIU Bound
12-29-2007, 10:16 AM
1971 27' Overlander
Central
, Ohio
Airstream sells the ones just like you have in regular and LED. They are the only place I was able to find replacements that came with a gasket. Not very expensive either - I recall like $4.50 per in regular.
12-29-2007, 12:18 PM
1993 34' Excella
Estancia
, New Mexico
Also Vintage Trailer Supply. The OEM lights are called "double bulls eye" and are standard. You can often find them at auto/ truck parts stores. I replaced mine with LEDs which had a jack at the end of the hot wire and no gasket I had to cut off the jack and make gaskets out of bulk gasket material to get the clearance between the light and skin. A gasket is not necessary to weather seal the LED unit but was helpful for the needed clearance.
12-29-2007, 01:35 PM
Retired.
, At Large
You can get the LED replacements that look identical to the ones you have for about $6 each from LED-R-Us.
LED-R-US LED'S FOR CARS, TRUCKS, SUV'S, TRAILERS, MOTORCYCLE, SEMI TIRE TOOLS
12-29-2007, 09:28 PM
1973 31' Sovereign
Danielsville
, Georgia
Brian,
You can purchase all 12 (5 red, 7 amber) for less than $30 from a truck supply house. (The marker lights run about $2 a piece)
I replaced all exterior lights, including tail/back-ups for less than $100 from local truck supply house.
Unless you're really set on LED, the original double bullseye will work for years (and was a real improvement from playing games with the originals)
Give me a call if need more info. I've still got all the part #s for the cans.
After playing games with the Overlander, I got serious with the Sovereign and replaced all lights and haven't had a problem with grounds/connections since.
12-30-2007, 05:36 AM
Loganville
, Georgia
Pizza Chop:
I bought two lights at Northern Hydraulics for 5 dollars each. They are the exact same as the ones on my overlander. All I will have to do is make a gasket for them. I can do that. I want to get up on top and start to get it in shape. That rain friday night proved to me I have some leaks that need attention. I was glad to put two huge tarps over the trailer because it is coming down pretty hard in Loganville.
I cannot do anymore to the bathroom until I get some welding done. I am going to yank the stove top cover off today and gather all metal parts that need refinishing. I found a place in Conyers that will powder coat everything for $30.00 dollars. I had the opportunity to see a finished product. It looked awesome and powder coat can with stand heat up to 400 degrees.
SIU Bound
Brian
12-30-2007, 06:11 AM
1973 31' Sovereign
Danielsville
, Georgia
Brian,
Do yourself a favor and replace all of them. You can seal around the top with Vulkem (use a small syringe).
Next time we talk I'll tell you about the 2.5 hours I spent in Chattanooga trying to fix my right taillight on the Overlander (near the beginning of a 12 hour first day of driving to Colorado).
As for leaks, one thing I did on the Sovereign that was well worth the effort was painting the top with white elastomaric paint (Kool Seal). I sealed up all the small rivet leaks, which amazingly, tend to add up.
12-30-2007, 07:18 AM
Surprise
Hey Pizzachop, I'm looking for the same cans that you had for the tail/stop lights, can I get the part #'s?
12-30-2007, 11:13 AM
1973 31' Sovereign
Danielsville
, Georgia
FireDog,
Behold!
I'm not sure of the part number for the clear lenses, but I'm sure you can get it from the Trucklite distributor.
12-30-2007, 12:42 PM
Surprise
Thanks Pizzachop, you've already been a great help just in my first month. This forum is the greatest thing since sliced bread. I just noticed that you have 7 little ones, I feel your blessing cuz I got 5 of my own. It's what life's all about huh.
12-30-2007, 04:00 PM
1973 31' Sovereign
Danielsville
, Georgia
FireDog,
It gets better than that! Mrs. PizzaChop (Brenda) is great with child (#8), due Jan 5!
We are on standby.....
01-04-2008, 05:46 PM
1986 25' Sovereign
Southern Middle
, Tennessee
Ron,
Working on the next Danielville, GA. baseball team? You and Brenda make great parents from what I have seen at the rallys so your kids are lucky. Hope Brenda is doing well.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
01-04-2008, 06:43 PM
Surprise
Hey Pizzachop, it's the fourth. Do we have baby #8 yet?
01-04-2008, 08:41 PM
1973 31' Sovereign
Danielsville
, Georgia
Craig,
They save their best behavior for the rallys. For a more sober assessment of our parenting skills, it's best to come to our house!
FireDog,
Out of 7 live births (last 3 at home), only one occurred on the due date. One was a day late, the others were days or even weeks late. No baby yet, but she's definitely very uncomfortable. Due dates are nice, but they don't mean much around here.
Craig,
See above...
01-04-2008, 09:22 PM
Surprise
Our prayers are with you all. And I agree that to better understand parenting you need to go where the kids re in their comfort zone.
01-20-2008, 06:42 AM
2006 30' Classic S/O
Mohrsville
, Pennsylvania
Replace Marker / Clearance Lights On '87 Excella - More Detail
Thanks for all the replies. I have attached some more pictures of what the wiring looks like coming out of the trailer and how the wiring mounts onto the light. My problem is that the replies all seem to have trailer lights that ground through one of the mounting screws. Mine DO NOT ground through the mounting screws. And there lies the dilemma. All replacements I have found so far ground through the mounting screws. I am hesitant to purchase an LED light too because I think I will be in the same boat. Does anybody know how my wiring set up works? Is the red wire a hot lead? Is the white wire a common lead? If I can’t find a replacement for these darn lights, I am going to be up the proverbial creek.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
01-20-2008, 07:19 AM
1975 23' Safari
1978 31' Excella 500
Franklin
, Indiana
Carl--My LED replacements DID come with both pos. and neg. wires...of course, my trailer had only the positive wire coming out, so I had to create a ground to the shell! Use a voltmeter to get your polarity squared away, but I'm guessing the red is the + since it is grommeted and that follows a normal convention for wiring colors. But, still, you should check it. It will matter to the LED's. Good luck!
Dallas Peak, MD 'That 70's Guy!'
VAC Past President
WBCCI #8481
01-20-2008, 07:39 AM
Retired.
, At Large
The new lights will ground right through the mounting screws, just make sure you use fresh mounting screws.
01-20-2008, 08:01 AM
Mohrsville
, Pennsylvania
DPeakMd--Thanks for the reply. I will be outside in the sub-zero Pennsylvania weather today trying to figure out the marker light wiring. I will keep you posted as things develop. And I just noticed I put the last post in the wrong thread. I was directed there by a post in the orignal thread I started regarding my wiring / light dilemma.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
01-20-2008, 08:10 AM
Mohrsville
, Pennsylvania
Overlander 63--I did that yesterday and all it did was blow fuses in my truck. I think I was creating a ground fault by connecting the white and red leads from the trailer to the one wire from the new lights I bought. It grounded out and blew the fuse in my truck. Of course the truck has the newer smaller fuses of which I had no spares. So it is off to the local Wal-Mart today to stock up on fuses.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
