Old 01-04-2008, 09:22 PM   #15
azfiredog300's Avatar
Surprise , Arizona
Our prayers are with you all. And I agree that to better understand parenting you need to go where the kids re in their comfort zone.
azfiredog300 is offline   Reply With Quote
Old 01-20-2008, 06:42 AM   #16
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Replace Marker / Clearance Lights On '87 Excella - More Detail
Thanks for all the replies. I have attached some more pictures of what the wiring looks like coming out of the trailer and how the wiring mounts onto the light. My problem is that the replies all seem to have trailer lights that ground through one of the mounting screws. Mine DO NOT ground through the mounting screws. And there lies the dilemma. All replacements I have found so far ground through the mounting screws. I am hesitant to purchase an LED light too because I think I will be in the same boat. Does anybody know how my wiring set up works? Is the red wire a hot lead? Is the white wire a common lead? If I canít find a replacement for these darn lights, I am going to be up the proverbial creek.
ID:	52791   Click image for larger version
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 01-20-2008, 07:19 AM   #17
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
Carl--My LED replacements DID come with both pos. and neg. wires...of course, my trailer had only the positive wire coming out, so I had to create a ground to the shell! Use a voltmeter to get your polarity squared away, but I'm guessing the red is the + since it is grommeted and that follows a normal convention for wiring colors. But, still, you should check it. It will matter to the LED's. Good luck!
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 01-20-2008, 07:39 AM   #18
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The new lights will ground right through the mounting screws, just make sure you use fresh mounting screws.
Old 01-20-2008, 08:01 AM   #19
DEITZ645's Avatar
DPeakMd--Thanks for the reply. I will be outside in the sub-zero Pennsylvania weather today trying to figure out the marker light wiring. I will keep you posted as things develop. And I just noticed I put the last post in the wrong thread. I was directed there by a post in the orignal thread I started regarding my wiring / light dilemma.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 01-20-2008, 08:10 AM   #20
DEITZ645's Avatar
Overlander 63--I did that yesterday and all it did was blow fuses in my truck. I think I was creating a ground fault by connecting the white and red leads from the trailer to the one wire from the new lights I bought. It grounded out and blew the fuse in my truck. Of course the truck has the newer smaller fuses of which I had no spares. So it is off to the local Wal-Mart today to stock up on fuses.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 01-20-2008, 08:56 AM   #21
Well Preserved
1993 21' Sovereign
To make a long electrical story short (pun intended), you should only have to hook up the power feed wire to the new lights. If everything else is kosher, the light should light with the ground going through the mounting screws.
remember K.I.S.S., and don't run more wires than you need.
Old 01-21-2008, 05:27 PM   #22
DEITZ645's Avatar
Problem Solved - Thanks
Thank you for all your helpful replies. I was making it much harder than it had to be, as pointed out by some of the posts. Today after running to Wal-Mart, I spent a small fortune in replacement and spare mini-fuses for the truck fuse block, and I finally got the lights to work. I put shrink wrap around the white ground lead terminal as I am hesitant to just cut the wire. There isn't that much sticking out from the trailer and I don't want to cut it short if I ever need that wire. I connected the red lead from the trailer to the black lead from the light and mounted the light to the trailer which provided the ground. When I turned on the truck lights the new marker light came on and didn't blow a fuse in the truck. It is bitter cold here in south east PA so the rest of the lights will have to wait until old man winter releases us.
We bought the trailer in Ohio as a second trailer to use on a permanent site at Penn Wood Airstream Park in Clarion, PA. Now I have to finish installing the laminate wood floor. After that it is off to P&S for an exterior make-over in mid-April. Then from P&S it goes directly to Penn Wood for the opening rally in early May. By the time we are finished with it, it should be better than new. I will post pictures as the floor progresses and finsihed product after it comes back from P&S.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Replace "Reading lights" with real reading lights and fans? Belbein Airstream Lifestyle 0 06-08-2014 12:30 PM
Replace clearance lights Okiegent Lights - Interior & Exterior 0 03-04-2011 08:43 PM
Replace Marker / Clearance Lights On '87 Excella DEITZ645 Lights - Interior & Exterior 18 01-21-2008 05:24 PM
Running marker / clearance lights unhooked Kistler Electrical - Systems, Generators, Batteries & Solar 19 12-18-2006 07:30 PM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
