Old 04-15-2010, 01:31 AM   #1
mistermike's Avatar
1968 17' Caravel
Marblehead , Hasslechusetts
Removing the 7-Conductor Wire
I would like to replace the 7-conductor cable that runs from the tv to my 68 Caravel.
I removed the access panel on the underside of the Caravel where the cable connects to the internal wiring but for some reason I cannot pull the cable out from either the A frame side or through the panel. Something seems to be holding it captive.
Am I missing something? Anyone have experience replacing the 7-conductor cable?
Any advice or assistance will be appreciated.
"Mister Mike", Chief Engineer, Amateur Radio Station W1RC
Founder and Benevolent Dictator, New England Amateur Radio Festival, (aka NEAR-Fest),
At the Beautiful Deerfield NH Fairgrounds (Next one May 4th and 5th 2018)
"Best #@! Hamfest on the Planet!"
www.near-fest.com
mistermike is offline   Reply With Quote
Old 04-15-2010, 07:51 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Can you post a picture or two. I would bet there is some kind of strain relief that needs to be back off before you can pul the cable out. This device keeps the cable in place so it won't come out when traveling.
Old 04-15-2010, 08:02 AM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
That is odd. I just replaced mine mine in the 67 Safari last week and once the wires were disconnected the cable pulled right out. Getting the wires apart through that little hole was a pain in the butt. Maybe Caravels have a trick to them.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 06:26 PM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 05:27 PM
Need new 7 conductor cable soldiermedic Electrical - Systems, Generators, Batteries & Solar 2 04-13-2007 03:17 PM
This wire doesn't look right? LI Pets Electrical - Systems, Generators, Batteries & Solar 10 09-02-2006 07:37 AM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
