Old 05-26-2011, 12:31 PM   #1
Usually Sleepy
biggoofball's Avatar
East Haven , Connecticut
Images: 14
Removing Tail Light on '73 Overlander. How??
Any idea how to get this these things out so I can re-wire them?
I drilled out the two rivets in each but they will not budge.
Thanks for any help,
biggoofball is offline   Reply With Quote
Old 05-26-2011, 12:40 PM   #2
Lothlorian's Avatar
Loganville , Georgia
They must be stuck because mine came out. I have a 1973
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 05-26-2011, 12:44 PM   #3
Usually Sleepy
Images: 14
I was a little afraid to use some persuasion even though I will not be using them anymore. I didn't want to break anything behind it.
I also seem to recall someone saying they come out from behind.
I'll go use a little more force and see what happens.
thanks for your input!
Old 05-26-2011, 01:15 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
A quick snippet from the repair manual.
Good luck,
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 05-26-2011, 01:26 PM   #5
Usually Sleepy
Images: 14
Thanks Tom!
After some extra persuasion I discovered an extra rivet at the base. drilled it out and "viola!"
both cans are out.
thank you again guys!
Old 05-28-2011, 02:07 PM   #6
Usually Sleepy
Images: 14
on the STT there are two wires coming out. brown and red. which is the tail and which is the stop?
thanks!
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 6 07-03-2018 12:26 PM
Tail Light Monitors? MDSilverado Lights - Interior & Exterior 3 10-19-2015 08:15 PM
'71 safari tail light/brake light issue TGK Lights - Interior & Exterior 8 08-20-2011 06:45 PM
Stereo With Overhead light?? Eliminator46 Audio, Video & TV 10 05-20-2011 03:12 PM
Flash of Light !! donking General Repair Forum 8 01-24-2011 03:16 PM
