Old 04-08-2012, 12:03 PM   #1
DougZ's Avatar
1972 27' Overlander
Venice , Florida
Removing tail light bezel.
I give up. I can't figure out how to remove the tail light bezel on my 1972 Overlander. I sure hope I don't have to remove the interior panels to get to them.
TAC FL-1
W4JDZ
DougZ is offline   Reply With Quote
Old 04-08-2012, 12:27 PM   #2
That tail light bezel is riveted in place, from inside the exterior metal.
You can easily remove it by shearing off the rivets with a putty knife.
Then you can reinstall the bezel with long # 8 pop rivets.
Old 04-10-2012, 03:55 AM   #3
DougZ's Avatar
1972 27' Overlander
Venice , Florida
If I am reading this correctly, I do have to remove the interior panels to insert the rivets - correct? Do you have to do this each time you want to change a light bulb too?
TAC FL-1
W4JDZ
Old 04-10-2012, 05:14 AM   #4
Insert the rivets from the outside.
They will show, but that will not hurt anything.
Old 04-10-2012, 07:18 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If I understand Andy, you can do it from the outside by shearing off the rivets then using new #8 long rivets reattach the bezel from the outside.
Old 04-10-2012, 04:58 PM   #6
Right on.
You got it.
Old 05-14-2012, 01:06 PM   #7
mfranken's Avatar
1971 27' Overlander
Amsterdam , NH
Did it work? And can you share pictures? I'm about to do the same on my '71 Overlander.
Amsterdam, the Netherlands, Europe
http://www.airstream-club.eu
mfranken is offline   Reply With Quote
Old 05-15-2012, 03:55 AM   #8
DougZ's Avatar
1972 27' Overlander
Venice , Florida
I didn't try it. I have no place to insert rivets without drilling through my tail light bezels, and I'm not about to do that. I will wait til this summer and go at it from the inside. It's going to be a pain, but it will be better than having cobbled up tail lights.
TAC FL-1
W4JDZ
Old 07-14-2012, 02:08 AM   #9
mfranken's Avatar
1971 27' Overlander
Amsterdam , NH
Hi Andy, I'm about to reattach my bezel again, but what are #8 long rivets, googles for it, and looked at Blind Pop Riveting
Can I also use screws? Any references, as I need to find corresponding material in Europe.
Thanks in advance
Old 07-14-2012, 08:46 AM   #10
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I inserted heli-coils on mine after I converted them to LED. Now they just screw on from the inside. I plan on making access panels on the inside so if I ever have to remove them again it will be easy. My Taillight mod begains on post 276 below.
Old 07-18-2012, 12:41 PM   #11
mfranken's Avatar
1971 27' Overlander
Amsterdam , NH
Did it! Used 3mm drill and screws in four corners.
ID:	163379   Click image for larger version
ID:	163381   Click image for larger version
Old 09-02-2012, 01:33 AM   #12
ewaegeman's Avatar
1970 31' Sovereign
1978 31' Sovereign
1978 31' Sovereign
pinkenba , QLD
Hi, Can I ask how to remove the taillight the easiest way ?, I removed the lenses and saw a couple of rivets in the middle, are these the ones to drill out?
Thanks.
Erik
ewaegeman is offline   Reply With Quote
Old 09-02-2012, 02:37 AM   #13
mfranken's Avatar
1971 27' Overlander
Amsterdam , NH
Hi erik, There are 4 rivets in each corner. From the inside though. My left one was pretty loose and came off by using a knife.
Groet, Michael
Old 09-02-2012, 02:41 AM   #14
mfranken's Avatar
1971 27' Overlander
Amsterdam , NH
Groet, Michael
Here's a picture
LED Tail light kit for the round '65 to '74 Airstreams Dan@LED4RV Commercial Listings 16 10-24-2012 05:45 AM
value of roof spot light gloran General Motorhome Topics 8 04-21-2012 09:01 PM
2 Red LED light in Rear bath? VeggieBullet Lights - Interior & Exterior 6 04-06-2012 11:44 AM
tail lights Angary Lights - Interior & Exterior 4 04-06-2012 05:56 AM
corrosion ? around light fixture? Lily&Me General Interior Topics 20 04-04-2012 11:26 AM
