Old 09-02-2012, 02:16 PM   #15
ewaegeman's Avatar
1970 31' Sovereign
1978 31' Sovereign
1978 31' Sovereign
pinkenba , QLD
Dank U, where you backup reversing lights connected ? I am planning to swap the indicators with the backup lights, and indeed put an amber bulb in it as you can't have red indicators in Australia, at the front connect the reversing wire to the brake lights. Hopefully I can rescue the bulb fitting as it it stuck down, didn't come up when I replaced the bulb.
Veel dank en groetjes. Erik, The Belgian in Australia.
ewaegeman is offline   Reply With Quote
Old 09-02-2012, 03:27 PM   #16
mfranken's Avatar
1971 27' Overlander
Amsterdam , NH
Hi erik, i did change the lights too. Reverse are now left and right indicators. Using orange bulbs. I had to make an extra wire though since the indicators are normally connected to the the red (middle lights) and the outer white lights are one the same wire from the front.
Mike
Amsterdam, the Netherlands, Europe
http://www.airstream-club.eu
mfranken is offline   Reply With Quote
Old 09-13-2012, 04:16 AM   #17
ewaegeman's Avatar
1970 31' Sovereign
1978 31' Sovereign
1978 31' Sovereign
pinkenba , QLD
OK ,did it ... removed them as you suggested ... cleaned them up, put them back ... not sure about the colour , what do you guys think?
I have reused the reversing lights wire as brake lights (red light) and moved the indicator wire to the white lens, with an amber bulb in it, to be legal in Australia
ID:	168165   Click image for larger version
Regards.
Erik
Old 09-13-2012, 10:26 AM   #18
DougZ's Avatar
1972 27' Overlander
Venice , Florida
Looks good Erik!
TAC FL-1
W4JDZ
DougZ is offline   Reply With Quote
Old 09-15-2012, 03:57 AM   #19
mfranken's Avatar
1971 27' Overlander
Amsterdam , NH
Hi Erik, nice work. Good idea to change the wiring to make it work. I made an extra wire since I took only the left one off. I'm less impressed by the grey paint job. Why not sand it, polish and put back the blue line? Specially on a nice trailer like yours. Just my 2 cents.
Mike
Old 09-16-2012, 07:46 PM   #20
ewaegeman's Avatar
1970 31' Sovereign
1978 31' Sovereign
1978 31' Sovereign
pinkenba , QLD
You probably right Mike, it was a trial I guess, I thought it was a good idea ... but still not sure, will sit on it for a while and decide later .... :-)
Regards.
Erik
Old 09-17-2012, 04:13 AM   #21
DougZ's Avatar
1972 27' Overlander
Venice , Florida
I saw one that had them painted satin black. It looked pretty racey.
TAC FL-1
W4JDZ
LED Tail light kit for the round '65 to '74 Airstreams Dan@LED4RV Commercial Listings 16 10-24-2012 05:45 AM
value of roof spot light gloran General Motorhome Topics 8 04-21-2012 09:01 PM
2 Red LED light in Rear bath? VeggieBullet Lights - Interior & Exterior 6 04-06-2012 11:44 AM
tail lights Angary Lights - Interior & Exterior 4 04-06-2012 05:56 AM
corrosion ? around light fixture? Lily&Me General Interior Topics 20 04-04-2012 11:26 AM
