Originally Posted by wmbechtel
Some of our rear right tail lights are burned out. How can we remove the tail light to replace the bulbs? I have removed the four screws but it is not loose. Any ideas? 2014 19ft. Flying Cloud
I guess the 4 screws you are talking about are the ones on the side of the casting. If so you may want to put them back. The plastic bezels around the 6 inch lights pop off. Then you should be able to see the screws that hold them on. Past that, there may be some sealer holding them on
