Old 09-14-2016, 09:25 PM   #1
2005 19' Safari
2003 28' Classic
Port Lavaca , Texas
Refrigerator fan switch or fan
I noticed in a picture that the refer switch when turned on, guessing this is in the normal up position that it is lit up. So I am guessing my switch is shot, maybe not the fan itself. Problem is getting the switch out, it has zero slack in the wires, if I pull on it, it will disconnect all together. I am guessing it is not a fuse either since everything works inside, except the refer fan of course.
dugan is offline   Reply With Quote
Old 09-15-2016, 12:01 PM   #2
2005 19' Safari
2003 28' Classic
Port Lavaca , Texas
2005 19' Bambi frig fan / switch
[QUOTE=dugan;1850979]I noticed in a picture that the refer switch when turned on, guessing this is in the normal up position that it is lit up. So I am guessing my switch is shot, maybe not the fan itself. Problem is getting the switch out, it has zero slack in the wires, if I pull on it, it will disconnect all together. I am guessing it is not a fuse either since everything works inside, except the refer fan of course.
The problem is, the fan never comes on when running the frig on electricity. So I don't know if it is the switch or fan, or both that is shot???
Old 09-15-2016, 12:27 PM   #3
check the fuse for the fan. it is in the side vent compartment outside the triler. mine was near the top vent opening. you can see where the fan temp. control is connected to the fin at top back of fridge and the wires follow to the fuse. my fuse was out and the fan light on switch and fan would not go on. it is a glas fuse so may not even look bad to your eye. get a NEW ONE AND SEE IF THAT IS IT GOOD LUCK
dsrtgrls is offline   Reply With Quote
Old 09-15-2016, 01:50 PM   #4
2005 19' Safari
GLENDALE , AZ
The fan switch controls the 12-volts DC going to the PC-type fan in the outside, upper vent next to the Bambi's entry door. There is also a thermostat in the circuit; so the fan may NOT run, even though the switch is ON (top side of rocker switch is depressed).
Also, this fan is wired separately from the 12 VDC and 120 VAC power used by the refrigerator; so fan operation is completely independent of all refrigerator settings, including OFF.
Old 09-16-2016, 03:59 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
The light in the fan switch on our 19' stopped working several times...and we replaced it several times... We finally gave up on the light... the switch still works without the light in the switch working... the top side of the toggle switch is down for "on" ... lower side of toggle switch is down for "off". And yes, the fan is on a thermostat, so the fan may not run even with the switch in the "on" position. It depends on the temp being detected by the sensor.
TB & Greg and Abbey Schnauzer
#3954
whats this switch? next to storage kill switch. Looking4air Electrical - Systems, Generators, Batteries & Solar 1 06-28-2013 02:59 PM
Refrigerator Fan Switch Location elirentz 2007 Safari SE 3 11-13-2012 08:13 PM
Refrigerator Fan/Switch Question eberrobw Refrigerators 19 07-22-2011 08:46 PM
Light Switch (Wall Switch) for 69 Overlander mbmbstreamer Lights - Interior & Exterior 3 03-21-2010 05:39 PM
switch for 12v supply to refrigerator nickcrowhurst Refrigerators 11 02-09-2004 03:33 PM
