Old 11-10-2010, 01:44 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Red or black?
I have new LED tail lights.(3 wires) white is ground. Is red stop,and black turn?Also I have a new seven pin U cord (6) 12's and (1) 10 the 10 is white and I assume is the ground?Clearance lights are grounded to ribs.Should I ground the LED tails to a rib also?I am connecting to a junction box that is color marked and notes what wire goes where.Where do I connect the license plate light as it is not marked.
bwaysteve is offline   Reply With Quote
Old 11-10-2010, 01:53 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Hook one up with ground,then touch your hot to red then black,the brightest one will be brake light.Just tie license light to the tail light. Dave
easyride is offline   Reply With Quote
Old 11-10-2010, 02:00 PM   #3
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Just wiring now.No battery in coach.
Old 11-10-2010, 03:17 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You can use a battery charger to test all of your circuits. Just connect the black lead to ground with a good connection and use the red lead to test all of the circuits.
Has anyone Ever?....Red numbers THEPILL Community Polls 54 02-12-2010 09:28 PM
Red awnings Hhthorny Awnings 7 04-18-2008 07:26 PM
seeing red codybear Off Topic Forum 19 10-13-2006 06:40 PM
Am I The Only Red Neck? Gwen Our Community 29 08-06-2003 05:48 PM
Re. red #s on front of AS ? jwaldin Our Community 4 12-29-2002 06:18 PM
