Old 05-11-2011, 03:52 PM   #1
somefun's Avatar
1974 27' Overlander
Puyallup , Washington
Recessed Light Installation
I thought I’d post some pics of my recently completed recessed lighting project. I installed ten 20w low voltage lights ( http://www.ylighting.com/mod88brrounb.html ). The six in the kitchen area are on the original circuit for the overhead kitchen light and the four in the living room area are on the circuit for the original light there.
The project was pretty straight forward. My biggest hurdle was placement; making sure I had them evenly spaced while avoiding wiring and the lateral ribs. Once I was certain of the placement, I used a drill mounted hole saw to cut the holes. That went very well (always remember to be careful to not go so deep that you drill through the outer skin)! I used electrical “fish tape” to fish the wires to the center ceiling panel area. I could access this area by pulling down on the skin an inch or two where the cut-outs for the ceiling vents are. I also used the a/c cutout for access.
The actual installation of the lights was very easy. They just sort of “snap” in place. I installed a double switch from Sailor Sam’s just inside the main door behind the stove. I couldn’t ask for better lighting! The amount of light is perfect! I’ve been planning this project for years and finally it’s done!
Curt
P.S. No, I don't like my pink curtains!
ID:	129628   Click image for larger version
ID:	129630   Click image for larger version
somefun is offline   Reply With Quote
Old 05-11-2011, 04:19 PM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Beautiful job! Looks like a pro did it. Nice!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 05-11-2011, 04:24 PM   #3
withidl's Avatar
2002 31' Classic
Houston , Texas
VERY clean; I like it!
withidl is offline   Reply With Quote
Old 05-11-2011, 05:13 PM   #4
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Way Cool! More guts than I have to drill into your lovely AS. Nice job.
Greg Heuer, Spirit of Virginia Airstream Club
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | Life Mbr ACI 1927 - Spirit of Virginia Club | AIR 53869
Silver Otter is offline   Reply With Quote
Old 05-11-2011, 06:09 PM   #5
somefun's Avatar
1974 27' Overlander
Thanks, guys! It took me 5 years to get up the nerve! !
Old 05-11-2011, 06:19 PM   #6
Splitrock's Avatar
Sioux Falls , South Dakota
It looks nice. So do I read that the power is 12 volt from the coach battery?
Click on the link to see a picture of the Sioux River falls near my home.
https://visitsiouxfalls.com/assets/i...uxfalls-og.jpg
Eastern South Dakota is very pretty with hills, rivers, and trees.
Splitrock is offline   Reply With Quote
Old 05-11-2011, 07:08 PM   #7
somefun's Avatar
1974 27' Overlander
Yes, they're wired into the original 12V lighting circuit.
Old 05-11-2011, 07:19 PM   #8
Splitrock's Avatar
That makes it better yet. Thanks!
Old 05-11-2011, 07:27 PM   #9
lucca53
lucca53's Avatar
1973 31' Excella 500
2004 22' Safari
2006 25' Safari
napa , California
I have the same color curtains! they work for now lol
lucca53 is offline   Reply With Quote
Old 05-11-2011, 07:43 PM   #10
A W Warn's Avatar
2000 25' Safari
Somefun,
Those lights look great!
How much clearance was there from the top of the light to the the outside skin. Did you push them into the insulation or did you have to remove some?
Old 05-11-2011, 11:13 PM   #11
somefun's Avatar
1974 27' Overlander
There's maybe a half inch or so between the top of the light housing and the outer skin. The insulation was pretty loose and doesn't get in the way. I didn't remove any.
Old 05-13-2011, 08:25 AM   #12
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I was looking at the information on the lights. It says " Not for ceiling use". My guess is that this is due to heat generation. Has this ever become an issue ????? Nice installation. I wonder if they have a LED unit that would reduce heat buildup ????
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-13-2011, 11:53 PM   #13
somefun's Avatar
1974 27' Overlander
Yes, I saw that warning too. It might be because of heat, or it could be because of size... they wouldn't work with 1/2" drywall because they're not very deep. I considered all of that and thought if they were made for cabinet or display lighting, how would heat be any less of an issue? I don't think it said anywhere not to enclose them (but I could be wrong about that). Anyway, I'm not concerned about any fire risk in the Airstream. They are very well constructed with metal, glass and ceramic components. It's only been about a week since I installed them, so time will tell! So far so good!
Old 05-13-2011, 11:56 PM   #14
somefun's Avatar
1974 27' Overlander
And yes, LEDs woud be much cooler and a good choice, I think. I actually purchased mine in 2005 (see what I mean about taking forever on this project? lol), and LEDs weren't available then.
Old 10-10-2011, 11:14 PM   #15
Dalmeny , Saskatchewan
Your lights look Great. Did you have much trouble running the wires with a fish tape in the ceiling? Was it much of a fight with the ceiling to get the wires to each location?
Davew is offline   Reply With Quote
Old 01-12-2013, 10:18 PM   #16
Brevard , North Carolina
May I ask what brand lights you used. I am currently restoring an International Land Yacht and want to put in recessed lighs. Your setup looks great. Did you have to worry about heat against the insulation?
Silver Trout is offline   Reply With Quote
Old 08-02-2019, 12:23 PM   #17
Whistler , British Columbia
I would also like to know this. How did you wire them up?
TylerG is offline   Reply With Quote
Old 02-06-2022, 11:14 AM   #18
funkill's Avatar
Tucson , AZ
Images: 27
Hi all,
I realize this post is fairly old but I stumbled upon it while trying to confirm being able to fish wires from recessed/puck lights through ribs WITHOUT removing the skins.... Seems somefun was able to do so - though not mentioned specifically.
I found this youtube video which also mentions being able to fish wires through openings in the ribs. Course, there are plenty of posts saying there are not openings in the ribs. Maybe it depends on year/ model (or just luck).
https://youtu.be/NElZga93MiU
Anyone have experience adding recessed LED lights in the ceiling without removing the skins or center panel in a 1973 Overlander?
Thanks -
FunKee - and the Silver Olive
2006 F-150 Lariat QuadCrew
AIR 31804
WBCCI 10718
funkill is offline   Reply With Quote
Old 02-07-2022, 11:59 AM   #19
I did it.
There are two channels in the center roof of the airstream. These channels are where the wiring of your airstream is. Google photos of airstreams without the skins on and you will be able to see them.
I used a wire fishing line to push the wiring through those channels. In some areas where it was more difficult, I drilled small holes that were the same size as metal plugs you can buy. Since I painted my skins drilling a hole and painting over the inserted plug was not a big deal. It turned out great and I did lights the entire length of the airstream.
You may need an electrician with pro fishing skills to help you.
Originally Posted by funkill View Post
Hi all,
Thanks -
New Warm white Recessed Puck Lights Dan@LED4RV Commercial Listings 17 11-11-2015 09:10 PM
New Light for the cedar closet Dan@LED4RV Commercial Listings 6 04-07-2011 07:04 PM
Flash of Light !! donking General Repair Forum 8 01-24-2011 02:16 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
