Old 10-14-2015, 12:38 PM   #1
PhiDor's Avatar
2007 34' Classic S/O
The Villages , Florida
Rear LED Tail lights
My LED tail lights on my 2007 Classic are going south. Quite a few of the small LED's have quit. I thought these were supposed to last a long time. Do I have to buy new ones? When you think about it, they really haven't been used much, but the old bulb type seem to last forever.
Phil & Doris Drugge
[COLOR="Red"]WBCCI #4941
"Jerry and our Amazing Dream Stream"
PhiDor is offline   Reply With Quote
Old 10-14-2015, 12:50 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Last July after picking up my new to me 2006 Safari I stopped by Jackson Center to get my rear lights looked at. They changed the LED modules out. No charge for that job. Of course managed to spend about $400 on other work done.
MICHAEL
Old 10-19-2015, 08:16 PM   #3
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
I have a 2009 Classic and my rear LEDs were burning out. While replacing them I found moisture had gotten inside the lenses. Apparently in 2009 there wasn't much effort placed on sealing the lense cover to the base and moisture was able to seep in. I also noticed the new replacement LED lense covers were better sealed to keep out moisture.
The reason sealed LEDs are so important is that unlike incandescent bulbs they don't generate much heat and it's the heat that evaporates any moisture. If LEDs are kept dry, they should far outlast incandescent bulbs. Just be sure they're sealed so moisture can't get in.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 10-19-2015, 09:36 PM   #4
Alice&Billis's Avatar
2006 25' Safari
Tyler , Texas
Replacement LED's
Just finished ordering four replacements this evening from:
Oval Red 60 LED Stop/Tail/Turn Lamp
Not my first time to replace one and I think these are priced reasonably. I also made online contact with the original manufacturer but never got a reply nor did I see my model in their online catalog so I went with the former. As I recall back in 2006, the case on the original had not been sealed and was full of water and it shorted out the LED's.
Alice&Billis is offline   Reply With Quote
Old 10-20-2015, 11:58 AM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
QUOTE=Alice&Billis;1699249]Just finished ordering four replacements this evening from:
Not my first time to replace one and I think these are priced reasonably. I also made online contact with the original manufacturer but never got a reply nor did I see my model in their online catalog so I went with the former. As I recall back in 2006, the case on the original had not been sealed and was full of water and it shorted out the LED's.[ QUOTE]
Please post to us how these worked for you when you've installed them...we need to replace ours eventually as well...and they cost a LOT from Airstream.
TB & Greg and Abbey Schnauzer
#3954
Old 10-21-2015, 08:10 AM   #6
2006 25' Safari
Tyler , Texas
Will do!
Old 10-24-2015, 04:04 PM   #7
2006 25' Safari
Tyler , Texas
LED Replacement
Name:	LED Replacement tight quarters male plug.jpg
Name:	LED Replacement sealing pigtails with caulk.jpg
Name:	LED Replacement sealed and plugged in.jpg
Name:	LED Replacement and beware the sharp neat cut aluminum.jpg
ID:	250965Received four new replacement LED signals in the mail as promised yesterday. They are identical, same manufacturer but these have a new part number. I sealed the two halves together with super glue, wiping excess off and neutralizing with a damp paper towel and finished up by liberally packing some caulking around the three wire inlet hoping these actions will slow the moisture infiltration. I found these popularly priced at $55.00 each but the supplier I used was selling at $22.50 each and that's why I went ahead and purchased two spares.
Old 10-24-2015, 10:00 PM   #8
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my original lights were slowly going bad. I bought what looks like what you bought and with pigtails. These lights have already out lasted the factory ones about three times. And still no problems. At the time that I bought mine on line, they were about $19.00 each.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Anyone know of LEDs for the rear marker lights on mid '70s on the tail lights? Mixter Lights - Interior & Exterior 8 11-11-2014 08:27 PM
LED Lights on 87 345 rear tail/turn Myrtle lynn Classic Motorhomes 19 02-28-2011 09:43 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
