Old 03-24-2011, 08:54 AM   #1
2011 20' Flying Cloud
San Antonio , Texas
Rear Camera installation wire thru existing lead via fish tape to trailer front
I am preparing to install a Rear view camera an wish to put the cable thru existing conduits to the trailer front battery box input.
Is this possible using a fish tape and which rear tail light fixture should I use?
Thanks in advance for your help.
Doug
KD2011 is offline   Reply With Quote
Old 03-24-2011, 09:29 AM   #2
jsapp's Avatar
1987 34' Excella
Bonifay , Florida
Is it a coax or single lead rca? When I converted from the 9 pin plug to a modern 7 pin I lost the use of the trailer mounted reverse lights. If your model has them it may be a good option...
jsapp is offline   Reply With Quote
Old 03-24-2011, 10:13 AM   #3
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Why not go wireless? Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 03-24-2011, 11:34 AM   #4
San Antonio , Texas
It is a 4 pin black cable about 1/4" dia.
The cable goes to transmitter up front which is then wireless to the screen in the towing truck cab.
Power comes from the transmitter unit up front, so I need a way to string that cable from the trailer rear to the front, hopefully inside some electrical conduit.
Doug
Old 03-24-2011, 12:21 PM   #5
San Antonio , Texas
Thanks everyone,
I just called the factory and there are no conduits to run a fish tape thru, so I will probably go over the top and between the window and rock guards up front. The camera will be above the rear window.
Old 03-24-2011, 01:15 PM   #6
Splitrock's Avatar
Sioux Falls , South Dakota
If you have a hollow frame, why not just bring the wire down and pull the wire at the trailer bottom location? If there's no frame route the wire could still be installed inside a casing and supported under the belly pan. Just my .02
Old 03-24-2011, 02:40 PM   #7
teagues's Avatar
2008 20' Safari SE
Charlotte , North Carolina
What system are you installing?
teagues is offline   Reply With Quote
Old 03-24-2011, 03:07 PM   #8
Images: 59
You can't leave the curtains open and see right through?
markdoane is online now   Reply With Quote
Old 03-24-2011, 03:31 PM   #9
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
KD2011,
I just installed on in my 2008 Safari. A wired camera all the way to the monitor, so power is from my TV. I mounted it above the license plate., drilled a hole thru the backouter skin and then another one thru the inner skin. This is inside my bath cabinet, then around under the toilet, under the kitchen sink, furnace, frig, and into the closet on the curb side. I just had to do a little fishing to there. then the amazing thing was to get it out and to the hitch. Well, there is a 1/2" hole from just back of my A-Frame in the cross beams. Luckilty I found it and your may have the same. Well I fished a 3/8" wooden dowell thru 3 holes in the cross beams and low and behold, it came out in the water pump access. I then used the dowell to guide a 1" Sch 20 PVD pipe thru to there for protection the camera cable. used a 45 deg elbow to finish it off on the underside and then ran the wire to the hitch. I have the same 4 or 5 pin plug for the camera.
Maybe your Cloud has this same hole in the crossmembers that you can access. It made my job a lot easier to exit my AS.
I was advised against the "wireless" as there is tooo much interference.
Or check for the hollow frame as per Splitrock. That should run front to back.
Why do you mention the rear tail light fixture? will you remove it to place the camera or just to get 12 volt power for the camera?
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Truck & Trailer Weights nickmeloy Towing, Tow Vehicles & Hitches 6 04-02-2014 10:02 AM
Parts needed - 345 Spare Tire Cover on rear, et.al. audiv8q Exterior Restoration Forum 0 02-24-2011 02:33 PM
'89 Excella, Mystery wire bundle, hitch area, photos cjack99 1987 - 1989 Excella 3 01-27-2011 04:03 PM
Front and Rear Window hinge - 1968 Randy Gates 1965 - 1969 Globetrotter 1 01-15-2011 10:05 PM
Landscape Wire Brianv512 Electrical - Systems, Generators, Batteries & Solar 13 01-06-2011 10:00 PM
