Old 12-29-2012, 06:20 PM   #1
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Re-inventing the scare light
I've never liked the scare light, the way it beams straight out, probably annoying the crap out of other campers. I tried to put a hood on it, but that got to be too hard, so I modified the original casting to take an LED disc and built a hooded replacement from scratch. The new light is only 1/4" larger in diameter than the original scare light casting, despite the appearance in the photo.
Name:	DSCN0794 scare compare.jpg
It's not impossible, but it is difficult, to get an LED disc to sit inside the casting right at the center of the lens, so you get some odd light rings on the ground near the Airstream, but the light output is still quite good. I haven't given up putting a hood on the original casting, but I'm leaving that experiment for another week.
Name:	DSCN0790 behind flange.jpg
ID:	175491 Click image for larger version
Name:	DSCN0791 flange installed.jpg
Building a hooded replacement for the scare light is doable, but I'm not sure I like the hood coming out 2-1/2". The next try will attempt a flatter section across the middle of the hood, or maybe some shrinking to bring the lip down a little. The good aspect of this replacement unit is that the light shines mostly down, there is no direct visibility of the LEDs to a person standing, and there is good illumination of the ground straight down. It's also wired so that in the dim mode only one LED is powered.
Name:	DSCN0789 cleco hood.jpg
ID:	175493 Click image for larger version
Name:	DSCN0795 hood done.jpg
The awning arm is a potential hazard for any light fixture that protrudes in the area of the scare light. We'll see how this one fares.
Zep
Old 12-29-2012, 06:30 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I agree. The scare light is pretty useless, except for spotlighting deer perhaps.
I also agree that a flatter version might look better. The current version does have a certain steampunk look.
Vaughan
Old 12-29-2012, 06:35 PM   #3
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
You went thru a lot of work, and it shows. Very nice. I took the easy way out, took our liitle dog's stainless steel water bowl, cut some openings in it and drilled the holes. The flange on the water bowl was a perfect fit for the light.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 12-29-2012, 08:08 PM   #4
Vintage Kin
Fort Worth , Texas
Zep, you are one cool dude! (in the best appellation of that).
Silver Streak also used this light. And, then by the time of my 1983 model (and new-to-me 1990 model) had this unfortunate choice:
RV Porch Light
I might try [4] of the new motion detector LED lamps at the OEM locations for these lamps, hardwired to 12V (new TT has black accent trim)
The Smart Light
But it would never be as cool as that hood over the marine-style light fixture!!
Old 12-29-2012, 08:14 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I was kind of thinking about removing the original, shining up the inside reflective background around the top 90 degrees or so, and painting the remaining reflector with flat black. Nice to dream about. Since it's never been apart, I don't even know if it's got an inside reflective surface.
Lynn
WBCCI 21043
Old 12-29-2012, 08:57 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
Nice work, Zep.
You've probably thought of this, but I would suggest a louvered approach as one means of reducing the distance by which the shade projects. Something like this only with larger louvers, and round, of course:
LED Mini Step Lights with Louvers, LED Louvered Path Lights, PNSI-661
While the aluminum would reflect some light it would scatter it and limit the glare.
Old 12-29-2012, 09:21 PM   #7
1965 17' Caravel
Birmingham , Alabama
Nice handiwork, guys! I had similar thoughts about the old-style porch light fitting on my 65. I installed a license plate lamp fixture instead. It points at the door where you need light anyway. It's low profile and looks good to my eye. And I can reinstall the original fitting if I choose to. There's a pic with my posted images if you are curious:
http://www.airforums.com/photos/show...mageuser=24848
Bill
gwchitty is offline   Reply With Quote
Old 12-29-2012, 09:31 PM   #8
Central , Mississippi
Originally Posted by Zeppelinium View Post
I've never liked the scare light, ...or maybe some shrinking to bring the lip down a little...
Zep
How about a mini 13 panel end cap?...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 12-30-2012, 10:21 AM   #9
1975 31' Sovereign
1977 23' Safari
Take a look at posts #28 and #30 in this thread about converting fixtures to LEDs. The conversion of the over-door light makes the scare light almost redundant, is a lot easier, can easily be dim for a porch light or bright for a BBQ light, and looks natural.
I did this because I've always thought there was a better way to do the scare light. I'm going to give it one more try.
Zep
Old 12-30-2012, 11:05 AM   #10
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Got A Picture of the Dog Dish?
Hi RLS,
While Zep's is the more elegant solution, I think I am more of a dog-dish technician. Have you a picture (or a link to a picture) of what the dish looked like before you took it away from the dog?
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 12-30-2012, 12:00 PM   #11
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
RE: Scare light
Zep and All,
I have no scare light currently on my '67 Safari. I have purchased (2) from another Airforums member earlier this year and in the spring I will begin the install process. I was toying with the idea of diverting the entire light assembly so it would not shine straight out at any neighboring trailers. What I intend to do is to form an "eyelid" from aluminum from the side of the trailer to the back of the existing light housing that will slightly angle the scare fixture downward.... so the full radius of the lens will still be throwing light but the angle will cause the lamp to shine more downward than straight out from the trailer, and be less offensive to nearby neighbors. If this process works out I will post what I come up with here. I am currently working out the angle so as to fabricate the aluminum bezel and form the top eyelid to divert water from the top of the fixture. Hopefully, the top of this new fixture will only protrude 1-1/2" from the original (flat) body mounted position but will still position the light @ a downward angle to divert the light suffficiently!
Stay tuned! Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 12-30-2012, 03:49 PM   #12
1975 31' Sovereign
1977 23' Safari
Well, I wouldn't exactly use the word "elegant," but it will do for now.
Name:	DSCN0804 portrait.jpg
Can't wait to check out the light pattern tonight.
Z
Old 12-30-2012, 03:57 PM   #13
Enthusiastic New AS'r
3campers's Avatar
1985 31' Limited
Glenville , New York
Images: 18
Those are really great ideas...love the dog bowl conversion. Until now I'd never heard it was called a "scare light"...we just use it to flood the campsite with light so the kids can play after dark...quietly of course!
1985 31' Limited
2003 GMC Sierra HD SLT 4x4
3campers is offline   Reply With Quote
Old 12-30-2012, 03:58 PM   #14
1975 31' Sovereign
1977 23' Safari
I think the shape I really want is this one. This quickie experiment used a 2x4 with radiused edges to form a blank, then I cut two slits so I could fold it. I didn't like the overlapping edges, so I cut 22.5 wedges along the slits and folded it to 45.
Name:	DSCN0805 blank shape.jpg
Name:	DSCN0808 net shape.jpg
The real deal would be a shape something like this:
Name:	DSCN0807 objective shape.jpg
The issue will be getting the corners at the fold to fit nicely. You can get a 3D print of this shape in stainless steel for about $50, but I am way too cheap for that.
Zep
Old 12-30-2012, 04:12 PM   #15
Alumaholic's Avatar
Images: 36
Which Dog Bowl, RLS?
Here's the line up. Can you identify your dog's dish?
Ken L
Old 12-30-2012, 04:43 PM   #16
richinny's Avatar
2011 34' Classic
zep, how about one with a sliding window to adjust the light wanted? :-)
Ricky
Old 12-30-2012, 04:49 PM   #17
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
But doesn't your dog find it difficult to get a drink now ???
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 12-30-2012, 05:23 PM   #18
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Originally Posted by Alumaholic View Post
Hi RLS,
Man did I get the evil eye when I picked up his dish OK, the measurements are 1 5/16" high and 5 1/8" outer diameter. I think the boss gets them from Petsmart. Best to measure before hand as there are several different small pet bowls. The bulb is led.
ID:	175570   Click image for larger version
Julia & Bob
W/ Deedee & Boo
AIR #30685
Old 12-30-2012, 08:53 PM   #19
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
I like the inspiration to have a "desighnor" scare light, so did a google on stainless steel bowls and came up with all kinds of options to try. If I ever get over this back issue I will be adding a new design to our Safari.
Zep is right though a lot will hinge on where then awning arm is in relation to the light. Might even be worth exploring adding another some where down the side more evening camp lighting, and/or out back for some rear hatch lighting... Thanks Zep for bringing this up! Happy Holidays all...!!
Barry & Karen in Mich.
goshawks00 is offline   Reply With Quote
Old 12-30-2012, 10:14 PM   #20
1975 31' Sovereign
1977 23' Safari
Originally Posted by goshawks00 View Post
... Might even be worth exploring adding another some where down the side more evening camp lighting, and/or out back for some rear hatch lighting......
I had the same thought until I checked the light patterns tonight. If you modify the over-door light, you get a lot of light along side the Airstream. On the Sovereign, I have good light well past the aft wheel. I think the scare light becomes redundant for sure. I was thinking of making a fixture that you hang on the drip rail of the aft window and find a place to plug it in.
But my real conclusion, after looking at the new over-door light pattern and the new scare light pattern, is that you need a 2-LED fixture above the front window, just to the curb side and a little above the "AIRSTREAM" letters. This would illuminate the hitch, as well as be an invitation light for the party. You can fish the scare light wire up to the eyebrow cabinet (take the cabinet out of the plastic dome, not as big a deal as it looks) and install the light from the inside of the dome outer shell.
Woohoo, a worthy next project. Zep
PS--the new scare light works as expected. Nice pattern on the ground and glare is shielded from the eyes.
