Old 02-15-2013, 07:30 PM   #81
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
Originally Posted by Zeppelinium View Post
It's a little unfair to assess the illumination level on the white snow--the bare ground doesn't glow that bright! However, the illumination level is quite bright even without the snow.
Zep
Agreed, the reflectivity of the snow does exaggerate the illumination, but the whiteness of the snow really shows off the light pattern and how even the illumination is. This is darned impressive to me!
I look forward to getting some big tasks behind me and work on some fun stuff like LEDs inside and out.
Good job sir!
Steve
Steve Bryant is offline   Reply With Quote
Old 02-18-2013, 02:47 PM   #82
Zep....
Did you only buy the flat lens versions?
Cos I have the convex ones... and I just had a brain storm...
I took the lens out and turned it inside out....
It fits!
The light is no longer a circular beam... its a mega flood light!
Light comes out of the lens and has a virtual 180 soft wide beam... little focus, just super wide and consistant!
I like it!
Try flipping your home made lenses?
Old 02-18-2013, 03:20 PM   #83
hissilver's Avatar
2018 25' International
Van Wert , Ohio
Nice work ... I will try you solutions
hissilver is offline   Reply With Quote
Old 02-18-2013, 03:38 PM   #84
Tricky to take some pics but here is the best I could do...
Lens in normal position...
Light output sitting on bench sideways...
You can clearly see the focused beam.
Light output vertical about 1 or 2" off bench..
Lens reversed...
Sideways on bench..
Note flat and wide flood of light.
Again, about 1 to 2" off bench..
Old 02-19-2013, 03:29 PM   #85
1971 29' Ambassador
guyton , Georgia
i bought a back up light for back of cab of a 18 wheeler polished and installed for $ 12.50 and it works good and looks good.
r.swanson is offline   Reply With Quote
Old 02-19-2013, 04:06 PM   #86
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Can you post a photo?
Old 03-24-2013, 04:45 PM   #87
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
We are glad to have the snow, but I agree with the prosecutor that Paxataunie Phil missed his spring forecast this year!
The LEDs have been on for over 2 months without a failure. They are operating at about half-power, which doesn't stress them at all. I find it intersting how obvious the color temperatures are--the spots are the warmest and the step light is way into the blue. I'm surprised at the pure white of the LED discs in the over-door light--they were advertised as "warm."
Name:	DSCN1038 snow LED.jpg
Zep
Zep@Charmedquark.net
Old 04-19-2013, 08:50 AM   #88
2008 23' Safari FB SE
Boulder , Colorado
Originally Posted by Lumatic View Post
For comparison here are some photos or the LED4RV scare light:1.The old scare light on 2. The new scare light uninstalled 3. The new scare light on.
It has 15 LEDs and it is very bright
Was the install on this pretty plug and play using the clip connector shown?
bonginator is offline   Reply With Quote
Old 04-19-2013, 09:23 AM   #89
Lumatic's Avatar
1993 34' Excella
Images: 16
I did not have to do a thing other than plug it into the old socket.
Old 12-09-2019, 11:04 PM   #90
2008 27' Safari FB SE
Sacramento , California
Originally Posted by RLS View Post
Man did I get the evil eye when I picked up his dish OK, the measurements are 1 5/16" high and 5 1/8" outer diameter. I think the boss gets them from Petsmart. Best to measure before hand as there are several different small pet bowls. The bulb is led.
I opted for the dog dish hack also. The serious advantage to this fix, in my opinion, is that you can literally screw the dish right over the existing fixture using the same screws. I got a bit more detailed with the dremel on mine, result was a slightly more OEM look. From 5' away it looks factory. (If I were more of a crafty person I could probably have improved that.)
ID:	357485   Click image for larger version
ID:	357487   Click image for larger version
shucklemoon is offline   Reply With Quote
