Old 01-07-2013, 09:53 AM   #29
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Originally Posted by Lumatic View Post
There was a recent post somewhere about a LED unit that is the same dimensions of the scare light, but I can't find it. ...
LED4RV had a complete unit with fixture, lens, and gaskets, which looked identical. I looked for it last week and it was gone. Maybe he'll get it back.
But it suffered the same issue as the original--a blinding light straight out to the side.
Zep
Old 01-07-2013, 10:51 AM   #30
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
It's there, SL30BW . I am going to order one. Let y'all know how it works out.
Lumatic is online now   Reply With Quote
Old 01-07-2013, 12:13 PM   #31
Nice work as always Zep!
I am trying to improve my exterior lighting too.
The motorhome has the similar scare lamp but also some docking lamps front and rear that were useless...
Here is how they look..
This is what I will be using there, and I thought I would share...
Ebay floodlamp..
Aluminum body, with 12v 10W LED.. about $12 each, shipped.
Casts a nice round beam..
I intend to modify my docking lamp mouldings and use teh lamp without the bracket, and fit them in like this..
I like your idea Zep, and might mod my scare lamp in a similar fashion to incorporate one of these...
Old 01-07-2013, 12:36 PM   #32
1975 31' Sovereign
1977 23' Safari
...Ebay floodlamp..
Casts a nice round beam...
Key, what do you estimate the beam width/circle is in degrees? A 10W LED must put out a heck of a lot of light. If the beam width is big enough, these look ideal to hang on the side of the Airstream once you're parked. I'm thinking of taking out the standard scare lights and putting an external 12V receptical in their place.
Zep
Old 01-07-2013, 12:50 PM   #33
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
I have been wanting to do something with my scare light. I know that an LED replacment is available. I had though about two pins and making the light swivel like a fish ceiling light. But I now like the idea of the hood to reflect the light down where it is more usefull.
I also like the idea of a receptical. Then you could control the patio awning lights by a switch.
Thanks for the new outlook.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 01-07-2013, 01:33 PM   #34
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Biggest obstacle right now with the scare light is that it intesects the pathway of the Zip Dee arm. Anything sticking out from the shell will stop the arm from folding against the body side.
goshawks00 is offline   Reply With Quote
Old 01-07-2013, 01:34 PM   #35
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Slick solutions....We don't use the "scare light" routinely because we don't want to annoy neighbors, especially if we happen to be in a commercial place where we are closer to neighbors. It's not so much of an issue when we are in a public campground or dry camping because we are usually further away from neighbors. I do like the concept of making the range variable somehow...
I have switched to an LED which helps to cut down the intensity of the light a lot. However, I still want to flood the area at times... especially when we are about to step out the door with the dogs at night to do their duty. We have seen beady little eyes in the distance that belong to skunks and/or javelinas...they all keep their distance, so in that respect the full flood "scare light" is useful.
TB & Greg and Abbey Schnauzer
#3954
Old 01-07-2013, 04:02 PM   #36
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Zep
I bought one but have not installed it yet.
Old 01-07-2013, 04:06 PM   #37
1975 31' Sovereign
1977 23' Safari
I'm surprised yours is like this. All three of mine that have scare lights have a minimum of 1" clearance between the inside of the scare light mounting circle (rivet circle) and the arm.
But it's definitely a hazard.
BTW, KEYAIR, I did some shopping today for LEDs and I noticed that the ads have changed since the last week of December. Many of the ads for the LED discs that previously (and accurately) stated they used 2W now say 10W. I wonder if yours is really 10W.
TBRICH, maybe you have discovered that the "scare light" is aptly named!
Z
Old 01-07-2013, 05:56 PM   #38
Hi Zep!
I will take some measurements of how much the beam spreads upon distance from floor.
The lamps are still on Ebay as 10W and they quote it as 800/900 lumen output. I got the one with the round lens, but they sell them with a flat lens...
I see no reason to keep the scare lamp as is... I want good illumination in the awning and doorway floor area.
Old 01-07-2013, 06:32 PM   #39
1975 31' Sovereign
1977 23' Safari
..I see no reason to keep the scare lamp as is... I want good illumination in the awning and doorway floor area.
Looking forward to the measurements. The flat lens is very interesting. I'll jump on eBay tonight.
After making the 2-disc fixture, I wanted to see if I could illuminate the front corner without too much ugly. I installed the fixture above the curb wing window and waited for night to fall to see what light pattern I got.
Name:	DSCN0827 front light install.jpg
The following panels show the front light, the over-door light, and then the two lights together. The trailers have a burm rising on the curb side, so you'll have to guestimate what the pattern would be on flat ground. I took the photos from up on the berm, so the photos are looking down.
Name:	DSCN0835 front light.jpg
Name:	DSCN0837 door light.jpg
Name:	DSCN0840 together.jpg
Note that the over-door light also has a step light on the same circuit. It's made from four 3-LED segments from the 5m LED tapes that are available lately (may cut down to two or even one segment). This one is obviously cool white. It looks way too bright when the over-door light is dim, but it's not that bright to the eye. I'm still going to dim it down a bit, however. Right now it has a 180 ohm series resistor which I'll pump up to 270 or 330. I may also dim it a bit in the bright setting.
I really wanted to illuminate the propane and tailgate area (I often use a small grill on the tailgate) and I'm satisfied that I met that objective.
Name:	DSCN0831 tailgate.jpg
For comparison, here is the over-door light on the other Safari (taken on level ground, not up on the berm). It has a slightly different arrangement of the LEDs inside the fixture, but I think it has a very similar light pattern on the ground.
Name:	DSCN0841 door light 77.jpg
The current draw for each fixture on dim is 90-100 milliamps. On bright the over-door draws 590 ma and the front light draws 380 ma. The step light on bright draws 130 ma and, on it's current dim setting, draws 30 ma. It's hard to believe that 30 ma is too bright.
The over-door light provides good illumination well aft of the door and out from the trailer at least 20 ft. This is plenty for under the awning and BBQs, particularly since the front light can illuminate a grill out from under the awning. I don't see any reason to re-install a light in the scare light hole.
I'll post some photos tomorrow on how to fish the wires and install the dimming resistors. Getting the step light installed looked impossible but turned out to be pretty easy.
Zep
Old 01-07-2013, 06:39 PM   #40
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
Zep,
As the Brits might say, it's brilliant...absolutely brilliant!
God job my man!
Steve
Steve Bryant is offline   Reply With Quote
Old 01-07-2013, 06:59 PM   #41
Usually Sleepy
biggoofball's Avatar
East Haven , Connecticut
Images: 14
Cool idea. Your second design made me think of one of these:
http://mcdn.toolking.com/catalog/pro...mp_Metal_C.jpg
Could save a little sheet metal fabwork starting here. Didn't measure or anything. just a thought. Thanks for getting my mind going!!
biggoofball is offline   Reply With Quote
Old 01-07-2013, 07:41 PM   #42
1975 31' Sovereign
1977 23' Safari
Originally Posted by biggoofball View Post
...Could save a little sheet metal fabwork starting here. Didn't measure or anything. just a thought...
I actually looked at HVAC sheet metal parts, but they are too thin. A better choice would be the replacement castings for the over-door light that INLAND ANDY has at Inland RV. If anyone knows of any light fixtures that approximate the scoop or shovel shapes I've made, I'd love to hear about them. Z
