Old 06-01-2015, 05:40 PM   #1
1968 26' Overlander
Portland , Oregon
Rally Lights trick not working...
I've followed everyone's advice and tried to get my marker lights to come on when parked, but to no avail. We are new owners, but the lights all worked when we brought it home recently. I've tried a wire connecting the pins, and using a 10 amp fuse in the 7 pin slots. No avail. Any advice where the problem could be? To be honest, I am not sure where the marker lights would have a fuse inside the trailer, assuming there is one.
1968 Airstream Overlander
AirstreamPDX is offline   Reply With Quote
Old 06-01-2015, 05:43 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I would check the "ground" circuit(s). Check first at battery the. See if the frame ground is intact. You do own a decent VOM?
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-01-2015, 06:00 PM   #3
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
I had the same problem on our Argosy. Eventually I took apart the 7 pin plug on the trailer end and found that the PO had reversed 2 of the wires - don't remember which ones. I used my multimeter to confirm what wire went to what connector on the truck and re-wired the trailer's 7 pin to match and the clouds parted and all was right with the world.
DryFly is offline   Reply With Quote
Old 06-01-2015, 07:54 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Could be a problem in the plug.... The "ground"' is common to all and all are acting up... Could be the ground is loose in the plug.
Channing
WBCCI# 30676
Old 06-02-2015, 01:35 PM   #5
macofpei's Avatar
2003 30' Classic
Stratford , Prince Edward Island
Send a message via Yahoo to macofpei Send a message via Skype™ to macofpei
Do the lights work when plugged into your TV? If so then it isn't your plug problem. To make the lights work, while unplugged, you need to "jump" the two pins on either side of the bump on the plug. Jumping the wrong two will blow a fuse.
Mac from PEI
Canada
WBCCI #4782
"Southern Belle"
'03 Classic 30'
'10 Toyota CrewMax
macofpei is offline   Reply With Quote
Old 06-02-2015, 02:21 PM   #6
1976 31' Sovereign
Oswego , Illinois
IE pins at 11 oclock and 1 oclock [top of plug]. I use 10 amp new style fuse. But this is on 1976 AS I don't no how your trailer plug is wired.
Old 06-04-2015, 05:50 PM   #7
2012 27' FB Eddie Bauer
Laguna Niguel , California
unplug the electrical plug from your tow vehicle point it towards your face. Orient the keyway lug to twelve o-clock position Make a jumper wire about six inches long. Plug in one end into the connection at eleven o-clock position and the other end into the one o-clock position and bingo
TSOMMY is offline   Reply With Quote
1976 Argosy 28 Brake lights, turn signals, running lights not working!!! Argosy1976 Batteries, Univolts, Converters & Inverters 6 06-22-2012 05:20 AM
Sticky Window Trick Foiled Again Windows & Screens 18 07-13-2008 04:06 PM
paint can lid trick pinkflamingoes Lights - Interior & Exterior 1 02-13-2006 08:43 AM
what's the trick? baxter Sinks, Showers & Toilets 0 11-21-2005 06:40 PM
Try this!! Window frame oxidation removal trick... niftypkg Cleaning, Stripping & Polishing 2 08-23-2002 05:49 AM
