Old 08-04-2014, 02:02 AM   #1
Pacific NW , Washington
Questions on replacing exterior outlet, reflector, & mystery electric socket
Hello, I own a 59 Tradewind and have some questions about some mystery parts. I have what looks to be an electric socket but I don't know what it would be used for?
I also have a reflector in the front (street side) corner that is clear. I looked around at other 50's trailers and have yet to see another with a clear reflector on the front corner. Anyone know the purpose of this? Should it be clear?
And lastly I have an exterior outlet that is falling apart street side just aft of the entry door. After inspection it looks like the latch is coming apart and I am not sure how it keeps water out as it is not air tight and I see no gaskets? Should I restore this piece or replace with a newer version?
Thanks guys!
dgreen78 is offline   Reply With Quote
Old 08-04-2014, 02:25 AM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I don't know what the twistlock outlet was used for, hopefully not a "power in" socket because the cord would be way dangerous.
The reflector used to be red but the sun bleached out the color.
The second outlet can be fixed with a new cover.
Old 08-04-2014, 05:29 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
What JMorgan said ^^**^^
As JM states, the first one looks like it came from Dr. Frankensteins laboratory and spare parts emporium... It also doesn't appear watertight.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-04-2014, 12:17 PM   #4
2005 19' Safari
GLENDALE , AZ
The first photo is a 15-amp twist-lock receptacle. (Besides finding replacements on the Internet, it appears to be stamped in the metal mounting hardware on the part.
The second photo is a white reflector. Just guessing; a PO probably added it, perhaps to be able to locate the Airstream or doorway, in the dark. Prior to a 1968 change in Federal Motor Vehicle Safety Standard 108, a lot of vehicles had white turn signals and reflectors on the front.
Regarding the last photo, it's up to you to decide if you want to clean up the original part. If you replace it, I suggest you look at replacement receptacles in a marine parts catalog or online (e.g., West Marine). Marine parts are usually made of stainless steel, and will look nicer and last much longer.
adding reflector to roof.. Bill M. Roof 15 09-26-2011 11:44 AM
Patio Light Reflector Melting JBinKC Lights - Interior & Exterior 12 09-02-2010 11:46 AM
Brake light reflector housing '65 Ambie bwaysteve Lights - Interior & Exterior 0 07-23-2010 11:39 AM
Where to buy lower back side reflector? goldenlily All Argosy Trailers 5 10-02-2009 08:47 AM
Bad swivel light ball & socket Rick T Electrical - Systems, Generators, Batteries & Solar 12 05-15-2005 07:47 PM
