Old 10-14-2013, 01:17 PM   #1
crabbey1's Avatar
1976 Argosy 22
Pasadena , California
Images: 33
Send a message via AIM to crabbey1 Send a message via Skype™ to crabbey1
Question: How do I rewire a light fixture from 240v to 12v?
Hey guys!
My girlfriend and I acquired some great wall sconce light fixtures at a flea market this weekend. We want to incorporate them into the trailer but there is a problem. The salesman was from Denmark as were the lights. Being such they are also 240v (according to the bulbs that was still in the fixture)...
So here is what I would light to do: I would like to find a 12v fixture to replace the current 240v fixture. I want to use the same 12v LED bulbs I have around the rest of the trailer. Does anyone have any experience with this? Can the same 2-way switch be used with the 12v?
Any help would be great! Thanks!
Chris
Name:	2013-10-14 12.07.04.jpg
ID:	197828   Click image for larger version
Name:	2013-10-14 12.07.41.jpg
crabbey1 is offline   Reply With Quote
Old 10-14-2013, 01:30 PM   #2
Ottawa , ON
If the manufacturer used and Edison type socket (the most common one, same as used here since forever) there's nothing to do but change the plug. The plug that goes into the wall I mean, since it will likely be one of the European ones.
If it is a different style socket for the bulb, then see if you can use a 120V bulb with that style socket in it. If you can't, then change the socket too.
Old 10-14-2013, 01:41 PM   #3
crabbey1's Avatar
1976 Argosy 22
Images: 33
I think the socket is the same but I don't want to use it is 120v, I want to hardwire it into my 12v circuits. SO I think I need to change the socket out with one for a 12v LED bulb and then I should be good to go. I was hoping that maybe someone had done this before or had clarification...
Old 10-14-2013, 02:31 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
There are 12v incandescent bulbs available that will fit in 25, 50, and 100 watts.
There are also 12v LED bulbs. Search for "12 led bulb edison screw"
That would be the simplest. There is no need to replace the socket, and doing so is difficult because you may have trouble adapting the mounting provisions to another socket type.
Old 10-14-2013, 02:51 PM   #5
bganso's Avatar
1994 30' Excella
Truckee , California
We put these lights Diablo Sconce - Rustic Plain - Rustic Plain Sconce in our AS. The switches work fine (most have ratings that will work for any voltage up to 240v). For bulbs, we used 12v incandescent bulbs that fit the candlelabra bases. We also installed a ceiling fixture and used 12v bulbs in the standard bulb sockets. Realizing you prefer LED over incandescent, these sockets Single Contact Bayonet Base Socket: Light Bulbs Etc, Inc. can likely be adapted for your lights and will accept LED bulbs
bganso is offline   Reply With Quote
Old 10-14-2013, 03:01 PM   #6
crabbey1's Avatar
1976 Argosy 22
Images: 33
bganso - I found those Bayonet bases and they seem like I could just swap that out with the candelabra base I currently have and then I should be good to go, right?
Jammer - I did come across these LED Candelabra Bulbs. Could I literally just keep the fixture as is and use these bulbs? Will that be safe?
Old 10-14-2013, 03:14 PM   #7
crabbey1's Avatar
1976 Argosy 22
Images: 33
One other question: If I use a bulb rated at 110v but only draws 6v, all is good for the 12v circuit, right?
Old 10-14-2013, 03:31 PM   #8
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
DC12V E14 LED Light Bulb Mini Edison Lamp Solar Chandelier Yacht Interior Home | eBay
Those are for 120v AC. That means that it will have a circuit that changes 120v AC to the appropriate DC voltage for the LED (usually somewhere in the 2-5 volt DC range). You need one that has a converts 12v DC to the correct range. They make them.
No, it's still a 120v AC one.
Take a look here Boat/RVOther Edison Screw Base Bulbs | Boat/RV/Other LED Replacement Bulbs | Boat, RV, and Other Lighting | Super Bright LEDs, these are what you need. They are for 12v DC.
BTW, those fixtures should look great in the Argy!
On edit, take a look at these on ebay. They are 140mm tall by 33mm in diameter, so they should fit into those shades without interference. (I couldn't find the dimensions on Super Bright's site.) They are also available in warm white as an option (I prefer warm white, myself). Of course, coming from Hong Kong will take longer.
Vaughan
Old 10-14-2013, 03:51 PM   #9
crabbey1's Avatar
1976 Argosy 22
Images: 33
Thanks for that link Vaughn. I have ordered E14 (european socket) converter to e12 (candelabra socket) adapters. So that is sorted out... I need some of these 12v DC bulbs but I would prefer to get the ones shaped light a flame if possible. I will keep searching!
I will post picks once these are mounted...
Old 10-14-2013, 04:08 PM   #10
crabbey1's Avatar
1976 Argosy 22
Images: 33
Will these work? E12 Candelabra LED Landscape Lighting 18SMD 2XUL Chip 2W 12V AC Replaces 20W | eBay
Old 10-14-2013, 05:43 PM   #11
bganso's Avatar
1994 30' Excella
I think those would work fine, but I like the alternatives provided by vswingfield better. Going to order some LEDs myself
Old 10-15-2013, 08:18 AM   #12
1983 34' Excella
1967 24' Tradewind
Images: 32
Those look good to me. No problem fitting into the shades, and the price is certainly right. They're even in the U.S. already so they won't take as long to get to you.
I'd go with the warm white ones, myself. I find that even the warm white LEDs can still be a little cool, especially if you have incandescents or fluorescents with warm white tubes in the same area. The cool white LEDs look rather jarring next to the others.
Vaughan
Old 10-15-2013, 08:31 AM   #13
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
Now that they are making LED's with Edison bases, how long will it be before there are adapters available for use in RV fixtures? I like my wall sconces/lamps, but they only accept automotive bulbs. IMO, automotive LED's are way over priced when I can buy a household LED with an Edison base for less.
AIR 57698, TAC NM-9. http://www.flickr.com/photos/philipks/
PhilipKS is offline   Reply With Quote
Old 10-15-2013, 08:54 AM   #14
1983 34' Excella
1967 24' Tradewind
Images: 32
They are available pretty reasonably from eBay. From China, of course, but even the ones from U.S. sellers are made there. The higher prices reflect these dealers buying up front and keeping an inventory in the U.S. to reduce shipping times. You can save a bundle ordering from China and waiting, or you can get them more quickly and pay for it. Your choice.
Here's a quick link to a search for 1156 LED: (1156 led | eBay) I see some as low as six warm whites for $12.99. Even less for cool whites.
Good looking 6 wheeler you have there!
Vaughan
12v
