Old 03-25-2014, 06:50 PM   #1
2014 16' Sport
Abita Springs , Louisiana
Proper seal on exterior marker lights 16' Bambi
Brand new 2014 Bambi and under close inspection I would swear that a couple of the side market lights are not compressing the foam gaskets enough to prevent water intrusion because of the gorgeous curves inherent in the fuselage. Any thoughts on how to remedy this? I wouldn't think I could apply sealant around the gasket and if that is appropriate, I wouldn't know which sealant to use??
Thanks to all!
zoieone is offline   Reply With Quote
Old 04-10-2014, 02:50 PM   #2
2014 16' Sport
Anyone have any thoughts on this?
Old 04-10-2014, 02:57 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
In general the hole behind the light should be at the center where there is sufficient foam compression. If you believe there is a problem I would suggest cutting any protruding gasket material off, carefully, with a razor knife, then putting down a thin bead of Parbond along the top half and front exposure of the light. I would use masking tape to get a controlled bead. Done properly, it's fairly time consuming to perform.
Exterior marker lights Lifeisgood Lights - Interior & Exterior 20 04-17-2018 06:08 AM
Installing exterior lights-to seal or not to seal Belegedhel Lights - Interior & Exterior 7 10-26-2013 07:14 AM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
