Old 08-30-2010, 05:43 PM   #15
1978 31' Excella 500
SOUTH ANHERST , Ohio
Lights all working now --except rt. turn
Yes I got all working ,
but did find out, I some how got a blown fuse in the new F150 from some thing I did ??
I do not know what caused the blown fuse , but here is what I did .
I check all fuses in the truck and found and replaced the blown fuse and then replaced a the 7 way on the trailer with a new 7 way plug and matched the trailler to my truck. Now all is well
Except my RT. TURN Siginal will not function (blink) but I think I am just going to live with that issue, because I have Brakes Lights on this side as well as 4 way blinking when set from my truck so when I turn Rt. I guess I will just push the 4 way from my truck. As long as Brake Light works on this side I am good .
Hope that helps
Gosman is offline   Reply With Quote
Old 08-30-2010, 08:14 PM   #16
Splitrock's Avatar
Sioux Falls , South Dakota
Hi Gosman
Are you writing that the right flasher isn't working on the tow vehicle? Or is everything working on the tow vehicle and the tight turn signal lights up but doesn't flash on just the trailer.
What was the issue with the back up lights coming on on the tow vehicle when it's not in reverse? Maybe that could happen if the 12 volt power line from the trailer battery was wired to the back up light pin on the tow vehicle. That would mean your 12 volt charging line isn't working on the connection and it would mean that the back up lights on the trailer never come on.
If your truck 7-way was factory wired, I bet it's wired correctly. An easy way to resolve it all is to buy a 7-way tester at the auto parts store and test the tow vehicle with that. Then, if your trailer 7-way plug is like mine I just loosened the plug and plugged it into the tester. With a 1 amp battery charger, I found all the correct trailer wires by testing them with the battery charger, and then I wired the trailer plug to comply with the tester.
Next I had a molded umbilical cord and I couldn't see the wires on the molded end plug. The colored wire chart was not useful to me in dealing with the cord and I had the privilege of reversing two wires on my plug after I noticed my trailer back up lights were on all the time, and my trailer 12 volt line was only powered when I put the tow vehicle in reverse.
I had 4 elements to deal with. First, I had the tow vehicle 7-way plug, then the trailer 7-way, and then both ends of the umbilical cord. All 4 have to be right and all 4 use all 7 wires.
Just as a point of concern from experience, a previous owner of my trailer had disconnected the break away switch and stuffed the wires behind the panel. I believe my trailer had the original 1976 break away switch on it so I ordered a new one from Vintage Airstream parts company. The new switch looks like the OEM switch and fits on the OEM mount.
A good help to me in all my Airstream work has been the factory Service Manual I purchased from Airstream. I'd recommend anyone considering getting into self servicing and repairing Airstream trailers and vehicles to get one. The cost was $60 and it saved me from making mistakes that I'd have to re-do.
At first I thought everything's hard to get at on my trailer until I discovered that it's only hard to get at if I don't know where it's at . . . or how to get to it:-)
Gary
Old 08-30-2010, 08:21 PM   #17
Splitrock's Avatar
I thought I'd add that a jumper test light is useful as well, in working with the plug. There's one big thing to watch out for, and that's crossing the brake lights with the brakes. They can both look the same with a jumper, but they're not. The brakes get their power from a rheostat and it scales from low to high. The brake lights are full power. If they're crossed, the brakes will be all the way off or all the way on. That's not a good braking feature:-)
Gary
running lights toastie Lights - Interior & Exterior 34 04-11-2010 06:12 AM
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
no running lights dougnjano Lights - Interior & Exterior 13 08-02-2009 07:21 AM
No Running Lights Craftsman Electrical - Systems, Generators, Batteries & Solar 5 09-12-2005 07:47 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
