Old 05-06-2013, 03:43 AM   #1
Baltimore , Maryland
Pro needs your help (again)
Every now and then I get stumped(I am human) and I need to reach out for a little help. Below is a fuse/ relay that I found at the umbilical connection on a 1964 Overlander. I was hoping one of you might know how many amps this is? I cannot find any more markings except what you see in the photo. It is wired to the blue brake wire and one leg of the break away system. All the wiring is being replaced due to rodent damage seen in the second and third photos.
I am hoping some one knows what the amp rating is so I can replace it with a new one. Thank you all in advance.
Old 05-06-2013, 04:08 AM   #2
Jimbcole's Avatar
1958 17' Pacer
Tryon , North Carolina
That is a circuit breaker, but the info on the amperage rating is on the other side of it.
Jimbcole is offline   Reply With Quote
Old 05-06-2013, 04:33 AM   #3
On the underside? I will take it off the plate and look more carefully. I know what it is and where to get new ones, I just don't know what the amperage is.
Old 05-06-2013, 04:45 AM   #4
Images: 59
It really depends on the wire size. If it goes to the brakes (dual axle with 4 magnets), then a 20a breaker would be sufficient.
Some will argue that the breakaway brakes should not be protected by a fuse or circuit breaker, which begs the question.
markdoane is online now   Reply With Quote
Old 05-06-2013, 04:46 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Frank, I think the blue wire was the battery charge line from the tow vehicle in those days. The ones I've seen amp ratings on have been 20 amp.
Old 05-06-2013, 04:56 AM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Usual practice is to not fuse a brake circuit. That being said a 4 brake system would peak at about 12 amps.
20 Amps should be a safe number for the charge line as you are not likely to see more than a few amps charging. More if running an accessory off that line.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 05-06-2013, 06:24 AM   #7
rideair's Avatar
Frank,
Looks like 20amp breaker is the answer!
Any auto place should have them in stock.
Enjoy
Paul Waddell
rideair is offline   Reply With Quote
Old 05-06-2013, 07:52 AM   #8
lewster's Avatar
Naples, FL , Hood River, OR
IIRC, in my Tech Certification classes we were told to use auto re-set circuit breakers only on the brake lines, never a fuse of manual re-set breaker. This could be an early example of same.......and remember that the over current device (auto re-set circuit breaker in this case) is sized for the wire gauge that it is protecting. 12 AWG =20 amps, 10 AWG =30 amps, etc.
Old 05-06-2013, 08:13 AM   #9
dznf0g's Avatar
Oswego , Illinois
This is what I was taught many moons ago....and what I have always done. SELF-RESETTING is the operative word here.
-Rich-
Old 05-06-2013, 09:21 AM   #10
DFlores's Avatar
1968 22' Safari
I just came across the very same situation, I found the markings on the side of the housing after sanding down a bit to expose a 25 amp rating, replaced mine with a 30 amp resetting breaker.
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 05-06-2013, 01:52 PM   #11
Sure enough, it is 25 amps...
I think I will replace it with a 20 amp unit. I really appreciate everyone's input on this. Thank you all.
Red Max Pro? Slowride66 Cleaning, Stripping & Polishing 0 10-26-2012 06:06 PM
When to Call in a Pro? Airstream Dad Repairing/Replacing Floor &/or Frame 8 09-29-2011 02:46 PM
Red Max Pro Taxman Land Yacht/Legacy Motorhomes 6 09-28-2011 05:55 PM
What Safety-critical repairs to leave to a pro? Airstream Dad General Repair Forum 0 09-28-2011 05:35 AM
Even a Pro needs advice Frank's Trailer Works Clearcoat, Exterior Paint & Trim 24 02-15-2011 01:04 PM
