Old 05-24-2015, 05:38 AM   #1
1970 23' Safari
Thomasville , Georgia
Power question
Just came into possession of a 1970 Safari. Electrical has been updated it appears. New Coleman AC. Plugged up to my house (20amp) using a regular orange extension cord. Only ran the AC and turned a few light on and off. All was well. A few hours later interior lights not working. AC still runs. Any ideas as to what may have happened? Probably obvious but I'm no sparky.
Middy is offline   Reply With Quote
Old 05-24-2015, 06:03 AM   #2
SteveH's Avatar
Common Sense , Texas
The lights should be running on 12VDC, and the air conditioner on 120VAC. So you may have a situation where the 12 volt converter (charger) is not working, and the battery has discharged.
Or, you may have a fuse problem on the 12 volt supply.
Regards,
Steve
Old 05-24-2015, 06:09 AM   #3
1970 23' Safari
P.S. Just found the fuses in my converter were blown. Not sure why.
Old 05-24-2015, 06:38 AM   #4
Gainesville , Florida
Twenty amps may not be enough to power the trailer with Air on. Be careful. Jim
Old 05-24-2015, 07:26 AM   #5
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I'm not familiar with the specs for the Coleman AC unit, but I would be surprised if 20 amps (and your extension cord could actually be a 15 amp cord) is sufficient. After you've replaced all the blown fuses, I would try to run the AC when connected to a proper 30 amp power supply. Note that a residential dryer outlet does not have the proper power to run your trailer even though the plug looks compatible. Plugging a RV into a dryer outlet and frying the RV electronics is a tragic newbie mistake. Don't do it! Go to a campground to test this.
Bob Martel
WBCCI# 5766
Old 05-24-2015, 07:29 AM   #6
1970 23' Safari
Great feedback. Thank you! Back powered up after replacing fuses. Can I plug up again to recharge battery and not run AC or would that be bad?
Old 05-24-2015, 07:32 AM   #7
SteveH's Avatar
Yes, just don't run the A/C because it pulls about 16 amps.
Regards,
Steve
Power Converter & Power Supply Land Shark Batteries, Univolts, Converters & Inverters 8 05-11-2010 09:51 AM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 08:07 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
