Old 04-13-2007, 04:40 AM   #15
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
Well, this has me thinking. We have the same problem. Pot metal is actually a metal you can work with yourself. They sell kits for hobbyists...Model tin soldiers and model railroaders use it. I may have to investigate making a mold..........
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 04-13-2007, 09:54 AM   #16
kincaidjesse's Avatar
1966 28' Ambassador
Here , Illinois
Wow, John, if you can make them you may have a market! I would buy a couple! I have not tried to glue mine yet but at some point one will break.
kincaidjesse is offline   Reply With Quote
Old 04-13-2007, 12:27 PM   #17
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Well for what it's worth I have repaired two of the lights in the GT using to different methods. I did these a number of years ago so I'll give you what I remember. If you think it will work for you I'll go out and take a closer look to see in detail how I did them.
One way was a thin piece of threaded rod with a hook bent into the end, passed through the post and hooked on the inside of the lamp. The other end was attached to a bridge over the wall side of the post and snugged up. Isn't very flexable.
The other fix used piano wire in a similar fashion but required drilling of the ball. This made it much more flexable.
I think I've got another one coming loose. Maybe time to put together a post on rigging these things back together.
Hope this helps,
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 04-13-2007, 01:18 PM   #18
1966 28' Ambassador
Here , Illinois
Thanks so much! I can tell, I need to start compiling an Experts Repair Manual!
Jesse
Old 04-15-2007, 06:28 AM   #19
lewster's Avatar
Naples, FL , Hood River, OR
Molds
Hi John (and others),
I make molds all the time! I am also (in my other life) a custom goldsmith and have been making jewelry for 32 years (Custom Jewelry, Island Metalworks Custom Goldsmiths). I use a non-destructive silicone molding compound that will make a PERFECT reproduction of ANY material, (except liquids, of course!) even a leaf from a plant and it will have every detail present. I've done a lot of strange things like motorcycle parts, lamp parts and even out of production marine hardware, as well as jewelry.
If you need a new part made, I can also cast them in pot metal right into this mold, or cast them in bronze, sterling silver, gold or platinum, depending on your budget .
Anyway, let me know if you need this type of service!
Favorite Jerry-Rig? Dave Cole General Repair Forum 58 10-07-2013 09:50 AM
Rally pot luck menus Pahaska Stella's Kitchen 2 07-16-2010 05:57 PM
Looking for some good reading material!! John Off Topic Forum 14 02-25-2003 10:02 AM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
Leaks RyeDuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 07-02-2002 09:10 AM
