Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 11-28-2009, 10:22 PM   #1
Profile:  1964 24' Tradewind
printer , Kentucky
porch light
i have a 1964 tradewind, it has a light on the outside beside the window, where is the switch suposed to be, i replaced the bulb already! Thanks!
mitsy is offline   Reply With Quote
Old 11-28-2009, 11:07 PM   #2
silverleeper's Avatar
Profile:  1967 22' Safari
1960 Caravel
Edmonds , Washington
Airstream Registry
That light is sometimes referred to as a scare light. Try this tread Porch light only on Battery power????. This might too. Light switch???
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-28-2009, 11:30 PM   #3
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Airstream Registry
porch light
Greetings misty!
Welcome to the world of '64 Airstream ownership!
The switch should be a little toggle switch between the front edge of the entrance door and the jalousie window. You may find that the scare light has a ground or loose wire issue as well -- mine had both recently -- cleaning and renewing the connections solved the problem.
Good luck with your Tradewind!
Kevin
Kevin D. Allen
AIR #827
Porch light Apache_Camp All Argosy Trailers 6 09-12-2009 10:56 PM
LED Porch Light RLS Lights - Interior & Exterior 11 09-18-2008 12:19 PM
Porch light for sale azfiredog300 Roof Vents, Skylights & Fans 50 02-12-2008 12:09 AM
Porch light cleaning GlenCoombe Lights - Interior & Exterior 8 03-20-2006 08:02 AM
The $8 Porch Light Silverfly 1958 - 1963 Overlander 2 09-21-2004 07:25 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
