Old 07-21-2010, 12:35 PM   #1
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
Patio Light Reflector Melting
I'm sure my patio light can be seen from outer space. I think it was set on "stun" at the factory. In fact, I think the bulb has warped the reflector. What are your thoughts? Replace the bulb, the reflector, or just use the light as a defensive weapon? Best wishes, John
JBinKC is offline   Reply With Quote
Old 07-21-2010, 01:36 PM   #2
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
This is a common occurrence for Airstream's patio light. There are 3 ways to fix this after replacing the lens. One, never leave the light on for more than 2 minutes. Two, replace bulb with a lower wattage one. Three, replace bulb with an LED one.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 07-21-2010, 02:39 PM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
The other option is to your hands on a glass lens and you'll never have to worry about wattage or length of time the light is on.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-21-2010, 03:01 PM   #4
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
LED patio light
For around $22 you can get an LED array AND a new lense, from LED4rv.com Here's the part you're looking for, available in either warm or bright white light:
LED Bright White Upgrade for Outside Patio Light 48x68BW9016W [48x68BW9016W] - $21.95 : LEDs 4, Recreational Vehicles
I had the same problem taken care of under warranty, then went ahead and replaced it with the LED. Much smaller battery drain, and little heat generated.
Cheers,
Jerry
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 07-21-2010, 05:57 PM   #5
JBinKC's Avatar
2007 31' Classic
Thank you all! I love this website. -- John
Old 07-21-2010, 06:27 PM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
They are bright, aren't they? Reminds me of the helicopter lights.
Unfortunately, this happens routinely...unless you can find a glass lens. We just replaced the melted lens and the incandescent light bulb with the LED replacement (lens + LED pad) from www.LED4RV as well. Good guy, that Dan.
TB & Greg and Abbey Schnauzer
#3954
Old 07-21-2010, 07:01 PM   #7
JBinKC's Avatar
2007 31' Classic
Huey landing lights
That's right! I flew Hueys in the Army. We had to make sure our landing lights were pointed down or they'd melt they'd melt the paint. And if they were left on when you landed, they'd melt the runway or start a fire if you landed on grass. Airstream must have borrowed some technology from Bell. Best wishes, John
Old 07-21-2010, 08:54 PM   #8
_
after melting 2 or 3 lens with the oem bulb (replaced under warranty)...
i opted to take the SAFE, inexpensive approach and downsize the bulb.
after 3 years using a smaller bulb the results were NO more melting and plenty of light.
recently i crammed one of the led panel replacements IN to that spot,
but haven't used it enough to endorse the change.
the bulb was 'gratis' so my cost SO FAR trying it is zero.
but a new lens and RELIABLE incandescent bulb are under 10$, easy.
________
so before jumping wildly about how great leds are...read what the VENDOR sez in post #9, here...
http://www.airforums.com/forums/f206...ght-66969.html
cheers
2air'
Old 07-21-2010, 09:10 PM   #9
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Lucy's "scare" light did the same thing. We replaced the bulb with an LED array. It was still too bright and bothered the neighbors. SuEllyn made an aluminum louvered cover that did the trick. Here's a photo.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 07-22-2010, 06:51 AM   #10
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
I have been using the LED one for about 18 months. Have left it on all night many times with no problems of melting anything. I also made a cover from a stainless steel small dog bowl that has the right size diameter to go over the light with some cut outs.
Julia & Bob
W/ Deedee & Boo
AIR #30685
Old 07-22-2010, 09:17 AM   #11
_
good user report rls...
and VERY CREATIVE cover...
that could become an a/s factory option.
cheers
2air'
Old 09-02-2010, 09:03 AM   #12
Wise Elder
Jammer's Avatar
2010 30' Classic
I'm thinking that something like this
Amazon.com: Maxxima M42327 4" Round 30 LED Back Up Light - 3 Hole Flange Mount: Automotive
...that is designed from the GROUND UP as an LED lamp might be a better choice.
Old 09-02-2010, 11:46 AM   #13
2010 27' FB Classic
N/A , Texas
That looks like a good idea. If you do it let us know!
Patio LED light Dan@LED4RV Commercial Listings 16 08-19-2010 12:57 PM
Patio light reo Lights - Interior & Exterior 4 12-06-2009 03:56 PM
GE patio light H12 sealed beam philippes Electrical - Systems, Generators, Batteries & Solar 3 03-17-2007 08:20 PM
Sealing the Patio Light Cstar Lights - Interior & Exterior 1 08-15-2004 08:21 AM
Flood light lens melting nickcrowhurst Lights - Interior & Exterior 5 12-24-2003 08:38 AM
