Old 12-06-2009, 11:09 AM   #1
reo
2008 19' Safari SE
satellite beach , Florida
Patio light
I just purchased a used 2008 19 ft SE. I noticed the lens on the patio light is slightly warped or melted...from over heating I guess. Is this a common ocurrance or could there be a problem? Thanks
reo is offline   Reply With Quote
Old 12-06-2009, 11:13 AM   #2
Redcobra's Avatar
2005 25' Classic
LaSalle , Michigan
Mine is the same way. I thought it was to aim the light downward a bit. I don't think anything got hot and melted.
God Bless All the Airstreamers as they Travel
Redcobra is offline   Reply With Quote
Old 12-06-2009, 11:47 AM   #3
Scare light
The scare light, "patio light", should not be left on for hours.
It will overheat and distort the lens.
Summer or winter weather doesn't seem to matter.
Old 12-06-2009, 12:52 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The lens gets warped because the heat generated by the bulb starts to melt the plastic. If you want to leave it on for extended periods, you can replace with a 90 degree 1156 white LED, or get a #1003 bulb. The 1003 is lower wattage, and will not generate as much heat (or light).
Old 12-06-2009, 03:56 PM   #5
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
I had the same problem and replaced the lens ($7.95) and changed the original 1156 bulb to a 1141. The original 1156 bulb is rated at 2.1 amps & 32 candle power. The replacement 1141 bulb is rated at 1.44 amps & 21 candle power. The only problem is that the 1141 bulb only comes as a clear bulb, while the original 1156 bulb is also available in amber and be used as a "bug light". I havn't had a problem since changing it.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Green Rocker Switch - patio light geodrake Lights - Interior & Exterior 1 11-18-2007 06:16 PM
GE patio light H12 sealed beam philippes Electrical - Systems, Generators, Batteries & Solar 3 03-17-2007 08:20 PM
Sealing the Patio Light Cstar Lights - Interior & Exterior 1 08-15-2004 08:21 AM
'64 Globetrotter Patio Light Problem sdresen Lights - Interior & Exterior 1 07-26-2004 10:27 AM
And a patio on the roof, yet! Pahaska Our Community 2 11-11-2002 12:38 PM
