Old 04-07-2016, 01:13 PM   #1
2016 20' Flying Cloud
Granby , Quebec
Patio Led light
Hi everybody
I try to figure how to remove the scare light. Here's a picture of water inside.
Thank you for your help.
Flying cloud 2014
freddyb337 is offline   Reply With Quote
Old 04-15-2016, 12:41 PM   #2
Dan@LED4RV's Avatar
Denton , North Carolina
it snaps
Originally Posted by freddyb337 View Post
Hi everybody
Flying cloud 2014
Fred
The outer chrome ring snaps on and off. I took one off the shelf and took a picture. The ring comes with the light and no big deal if it breaks. The Airstream part number is 512532
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 04-20-2016, 05:16 AM   #3
Granby , Quebec
Thank You very much Dan
Old 11-03-2016, 03:13 PM   #4
2014 23' FB Flying Cloud
Wilmington , North Carolina
Originally Posted by Dan@LED4RV View Post
Fred
Hi Dan, do you know if a warm white version of this light is also sold?
thomasj is offline   Reply With Quote
Old 11-29-2016, 03:42 PM   #5
2015 28' Flying Cloud
Saint George , Utah
Sorry to sound stupid, how do you snap off the outer chrome ring? I suspect a water leak coming from the patio light, I attempted to pop if off. However, it does not want to release, and I don't want to break it.
Treker2015 is offline   Reply With Quote
Old 02-25-2017, 03:55 PM   #6
The Colonel's Avatar
2017 25' Flying Cloud
Navarre , Florida
Did you find out how to remove the ring? I've screwed so much with mine I'm afraid I've introduced a potential water leak
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 03-02-2017, 07:21 AM   #7
Navarre , Florida
I guess no one has figured how to find the hidden tabs then how to get them to release without destroying ring. Mueller?
Old 03-02-2017, 07:57 AM   #8
2013 20' Flying Cloud
Between Here and There and Nowhere , what have you got?
If you look at that fixture online, it appears the ring is an integral part of the light. A large threaded nut anchors it inside the wall.
openroad118 is offline   Reply With Quote
Old 03-02-2017, 09:23 AM   #9
Granby , Quebec
I'ts possible to remove the ring but you have to be very careful. When i removed it, i can figure how because i was in possession of the new light and ring. To remove, you have to use a little hook and protect the skin
Old 03-02-2017, 09:42 AM   #10
Navarre , Florida
That's what I was going to try as a last resort when we get back home. Sure would be nice if the tabs were indicated on the face of the ring. Thx
Old 03-02-2017, 01:26 PM   #11
DaveP's Avatar
2004 28' Classic
Monument , Colorado
You might try a paint can opener (like from Home Depot). Put a flat, thin putty scrapper between the skin and the opener to protect the skin. The openers have a very short lever to the fulcrum point, so they can exert a lot of force. Just work the pair around the ring until it pops off.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 10-09-2017, 01:23 PM   #12
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
I need to investigate mine. Once you get the outer ring off are there visible screws to remove the light?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 10-10-2017, 06:03 AM   #13
Dan@LED4RV's Avatar
yes
Yes there are 3 holes in the black base that hold the light to the Airstream.
If part of your LEDs are not working, and the light needs to be replace, a new light comes with the outer ring.
Dan Brown
Denton NC
Old 10-10-2017, 07:15 AM   #14
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Thanks.
LED Patio Lamp? philipsinewe General Repair Forum 1 06-08-2015 03:38 PM
LED for Exterior Patio Light jcanavera Lights - Interior & Exterior 8 06-10-2011 09:55 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
Patio LED light Dan@LED4RV Commercial Listings 16 08-19-2010 12:57 PM
