Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 03-16-2007, 04:27 PM   #15
neil.ervin
Profile:
I had the same problem. Surprisingly as it may seem, there was a bad bulb on the trailer exterior. Kept blowing the fuse in the tow vehicle motor compartment.
Actually the bulb glass would rotate around its metal stem. Replace the bulb, no problem since.........
And I was so sure it was the bulb fixture.
Neil Ervin, Phoenix, Arizona (Sun City Grand)
neil.ervin is offline   Reply With Quote
Old 03-16-2007, 04:30 PM   #16
andyfuson
andyfuson's Avatar
Profile:  2004 25' International CCD
Stone Mountain , Georgia
Thanks Neil,
I had hoped that was my problem. I have removed all of the bulbs as well as cut the wiring loose from the tail lights and the short is still there.
You were lucky.
Would rather be camping!!!
andyfuson is offline   Reply With Quote
Old 03-16-2007, 04:45 PM   #17
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
The fact that the license had a single wire is important. When you call Airstream for a routing diagram. If they do not discribe that light as the end of a series including all of the tail lights or as a seperate routing from another fixture, and say which fixture, they have blown you smoke.
Unfortunately Jackson Center all to often blows smoke when ask a hard question. When I was looking for parts for my roof vents I have had then claim they never used the parallel lift roof vents and that I had to have installed them.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 19 12-12-2003 08:39 AM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 10:09 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 05:51 PM
Courtesy Parking markjoandall Our Community 7 06-30-2002 02:07 PM
Blinking Galley Lights 1985air345 Mechanics Corner - Engines, Transmission & More... 7 06-23-2002 09:42 PM
