Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 08-08-2006, 11:27 PM   #1
Mark&Bet
Canonuts
Mark&Bet's Avatar
Profile:  1970 27' Overlander
Santee , California
Overlander exterior light not working
We have a 1970 Overlander that we just bought a few weeks ago. The exterior light above the door is not working. I pulled off the cover and there are 2 black wires coming out but when i flip the switch inside i get nothing out of either one of them. Can anyone help with maybe a suggestion of where to start? Thanks!
Mark&Bet is offline   Reply With Quote
Old 08-09-2006, 08:17 AM   #2
TOM CRUMP
TOM CRUMP's Avatar
Braxton , Mississippi
Images: 26
Mark and Bet
Welcome to the forum. A 70 O/lander! I also own a 70 O/lander. bought her in June and I am in the process of working the bugs out of mine also. Just got done replacing the axles, wheels and tires. On your light problem, if you see your wires connected all right, try flipping the rocker switch on and off repeat that several times. And check the bulb. Any othe lites out? If so might be a circuit problem, check circuit breakers and maybe fuses in your univolt, I hope you have an owners manual, I dont but i've owned 4 Airstreams, I was hoping some kind airstreamer who has a manual for a 70 O/lander would copy one for me, Anyhow let us know how you make out, And post some pics of your trailer
TC
TOM CRUMP is offline   Reply With Quote
Old 08-09-2006, 10:50 AM   #3
Hind-Sight
Hind-Sight's Avatar
Profile:  Murray , Utah
Tom,
Where are the fuses in the univolt? This may help troubleshoot my charging issue.
Andy S.
Murray, Utah
69 Overlander
01 Suburban
Hind-Sight is offline   Reply With Quote
Old 08-09-2006, 12:04 PM   #4
wacnstac
Profile:  1979 31' Excella 500
Detroit Area , Michigan
Images: 41
My first guess would be that the fixture is no longer grounded to the frame or skin of the trailer. This was the problem with both of my exterior lights.
wacnstac is offline   Reply With Quote
Old 08-09-2006, 04:45 PM   #5
Alumin8
Profile:  1973 31' Excella 500
Morristown , Tennessee
I don't know about your model but most univolts are in the bathroom closet for rear baths and under the counter near the water pump in the kitchen for center baths. It is possible to get the owners and service manual for your trailer from Secretarial Services.
Here's the address and telephone number. I got both for my 1973 Excella for $121. Saves a lot of headache but does not show every detail as you might expect. In addition, these are not new color copies but rather black and white copies that doesn't do the pictures justice. I still thought it was worth the price.
PO Box 484
512 N. Main Ave
Sidney, Ohio 45365
Joe
Alumin8 is offline   Reply With Quote
Old 08-09-2006, 05:50 PM   #6
Mark&Bet
Canonuts
Mark&Bet's Avatar
Santee , California
I tried testing both of the black wires coming out and neither is attached to a ground and neither is hot so it must be somewhere else down the line. There are 2 other ourside lights and neither one of them works either so i will jsut have to trace them back. Thanks for the comments.
Old 08-10-2006, 12:51 AM   #7
TOM CRUMP
TOM CRUMP's Avatar
Images: 26
The univolt is located inside the storage compartment, remove the nut, open the univolt door and check the fuses
TC
Old 08-10-2006, 11:44 AM   #8
gmshadow
Profile:  1969 27' Overlander
Chewelah , Washington
I just had the same problem. The outside light would not work, did not find any fuses bad etc. Pulled the switch, involves drilling out two rivets and dismantled the switch, cleaned up the contacts and light now works fine. Need to be carefull taking the switch aprt as there is a little button and a spring that might get away if not carefull. My switch was held together by 4 little tangs that need to be pried up. Or can just replace the switch if can find one, unlikely to find one to match I would think.
gmshadow is offline   Reply With Quote
Old 08-10-2006, 01:29 PM   #9
AirConditioner
AirConditioner's Avatar
Profile:
my brite ideas
I have a 72 overlander and replaced my corroded fixture with a cut-down submersible fixture from a boat trailer (any marine store). note that the AS fixture is fed + voltage and the negative is switched. consider replacing with an LED fixture to avoid burnout and heat buildup. the fact that your 'scare' lite also doesn't work suggests a fuse. good luck.
AirConditioner is offline   Reply With Quote
1966 Overlander International Double Tamara 1966 Overlander 30 03-28-2006 03:55 PM
73 Overlander for sale markdoane For Sale & Wanted 0 04-19-2004 08:28 AM
First shower in my 1975 Overlander !!! pjtaia Our Community 13 10-30-2002 08:52 AM
2-door Overlander InsideOut 1958 - 1963 Overlander 0 08-30-2002 09:14 AM
Looking at a 64 Overlander N80 1964 Overlander 1 06-02-2002 09:25 PM
