Old 04-03-2015, 07:22 AM   #1
1976 31' Sovereign
Springfield , South Carolina
Overhead lights in danger of shorting fix
Two of the four overhead lights had potential safety issues from corrosion found in the wire nut connections and the overheating of a wire connection on the 3 way switch that have have become hot enough to cause the insulation to flake off and operated from dim to bright depending on how you operate the switches.
I removed the wire nuts, cut the corrosion off, re-twisted them together and soldered them together, reapplied a new yellow wire nut and taped it in place with electrical tape so now all six bulbs will light when switch turned on.
I also have replaced the overhead bulbs with 1156 LED bulbs that operate much cooler and should never burn out.
I also ran in incoming hot wire to a 120v commercial switch with a shallow box I found at Home Depot so I now have switch mounted in plastic that is much heavier duty.
[IMG]http://[/IMG]
This light in bath room.
[IMG]http://[/IMG]
This light over the couch/eating area.
Both have the LED 1156 bulbs I got off ebay.
Hummer is offline   Reply With Quote
HELP...shorting somewhere Dixie722 Batteries, Univolts, Converters & Inverters 6 09-20-2013 07:29 AM
Battery Hold-down Strap Shorting Against Positive Battery Post rel Sprinter and B-van Forum 3 08-13-2013 10:32 PM
Breakaway switch wires shorting together Airperson Brakes & Brake Controllers 8 08-18-2012 07:42 AM
Parking lights shorting out andyfuson Lights - Interior & Exterior 16 03-16-2007 03:45 PM
refer shorting out art Refrigerators 4 04-30-2003 04:51 AM
