Old 12-31-2010, 12:10 PM   #1
Question Overhead Light Switch "HI-LIGHT-LO"
I have a 1993 34' Excella and need a replacement for the subject switch. While inspecting the switch, it fell apart in my hands and one of the connectors on the back broke off. The switch has six (6) connectors on the backside of switch. Any help would be greatly appreciated. Thanks, Mark
motilley is offline   Reply With Quote
Old 12-31-2010, 12:32 PM   #2
Mark.
How about a photo.
If I remember correctly, that switch is NLA, but, just in case, a photo would help.
Old 12-31-2010, 03:03 PM   #3
Please fi[nd attached photo's of subject switch.
Regards,
Mark
ATTACH]118330[/ATTACH]Click image for larger version
Name:	Airstream Overhead Switch, Rear Bedroom 002.jpg
Name:	Airstream Overhead Switch, Rear Bedroom 001.jpg
Old 11-07-2011, 06:06 PM   #4
88 Excella 34ft
Puck & Gumby's Avatar
1988 34' Excella
Valrico (Tampa) , Florida
I have the same switch in my 88 Excella.
Found a replacement but seem to wire it correctly, any help?
"Not all who wander are lost"
Tim and Susan
West Central Florida
88 Excella 34'
05 F250 SD 5.4
Puck & Gumby is offline   Reply With Quote
Old 11-13-2011, 02:21 PM   #5
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I have the same switches in my 87 Excella. The one on the bedroom ceiling works fine, but the one near the entrance door only works on high (and then only 2 bulbs of the 6 in the fixture light up). I pried the switch off its base and saw that one lead was missing . . . and the loose wire in the wall sparked when I tried to get at it. So it is booked for repair at Jackson Center for Dec 1st.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 11-13-2011, 04:16 PM   #6
Sorry folks, but that switch has not been available from Airstream for some time.
Old 11-14-2011, 09:40 AM   #7
As of today, Airstream does not have that dpdt switch, as well as no plans to obtain a replacement.
We will see if we can find a source, when we have time.
Old 11-14-2011, 10:34 AM   #8
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Good info here on page 4 to understand you switch design.
If the switch is burnt? can you clean and re-solder it?
http://www.elecdirect.com/Data/ProductPDFs/CHa6.pdf
Old 11-16-2011, 07:11 AM   #9
88 Excella 34ft
1988 34' Excella
Tim and Susan
88 Excella 34'
05 F250 SD 5.4
Old 11-22-2011, 03:01 PM   #10
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
That sucks!
However, when it comes to older odd-ball parts, there is a place in Quartzsite AZ(I think it was called the Joker) that has all sorts of stuff. Last year I saw that they had a set of mirrors for my (then) 1994 LY motorhome. When one of mine was damaged as part of a hit-and-run accident, the local AS dealer in Ottawa had to have it remanufactured at a machine shop. I'll be in Quartzsite in January and I'll look for those switches.
VE3JDZ
AIR 12148
Old 11-22-2011, 03:44 PM   #11
That sucks!
We are waiting for a shipment to arrive that will have that DPDT center off switch in it.
It looks like it will be the answer, but I will wait until it's in my hands.
Old 08-22-2017, 03:14 PM   #12
1988 34' Limited
Folly Beach , South Carolina
Hey there, I know this is an old post, but does anyone know if replacements for these are available? Or any aftermarket product that would fit?
Daddyo_1 is offline   Reply With Quote
Old 08-22-2017, 08:53 PM   #13
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
None available. I've had them replaced at JC with SPST rocker switches.
VE3JDZ
AIR 12148
Old 08-23-2017, 05:51 AM   #14
1988 34' Limited
Sorry if this is a silly question, but what is JC?
How to Light the Pilot in the Oven lcurrie Stoves, Ovens & Microwaves 3 08-01-2011 07:16 PM
Water Heater Pilot won't light giffy58 Water Heaters, Filters & Pumps 9 03-10-2011 06:56 AM
