Old 12-04-2011, 11:16 PM   #1
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Over the bed light switch stuck
Thats right, and it's been this way for about two years, because I have never figured out how to make it work again. It won't budge either. Andy? ...anybody? I hope this over sized file will load. well I have exceeded my picture limit...but it's the end switch for the light thats above the one twin bed in the seventy model...It either toggles up or down.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 12-05-2011, 02:55 AM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
You could try taking it apart and cleaning it. I did that with the scare light snap in rocker switch. Used some contact cleaner then a little lube of dielectric grease with a toothpick. Careful with the small spring and parts.
Otherwise, start searching on the internet (ebay has a ton of snap in rocker switches listed) old hardware stores, auto parts stores or electrical supply houses. You'll need the measurements of the opening it snaps into to find the right fit. The ones on Out of Doors Mart seem to large - Inland may have it listed somewhere or as a nonlisted item.
Overhead Light Switch "HI-LIGHT-LO" motilley Lights - Interior & Exterior 14 08-23-2017 06:11 AM
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 05:05 AM
I want my water pump switch to light up... Friday Electrical - Systems, Generators, Batteries & Solar 18 09-18-2011 10:03 PM
Light switch question SilverHoot Lights - Interior & Exterior 10 07-15-2011 08:44 AM
2006 Safari Interior light switch Goal15 Lights - Interior & Exterior 7 05-03-2011 01:36 PM
