Old 01-31-2015, 07:03 PM   #1
SilverEagle6's Avatar
2013 25' Flying Cloud
2008 30' Classic
On The Road To Wherever We End Up , Traveling the USA
Outside "Moonlight"
Anyone have a tip on how to remove the metal ring around the exterior moonlight? While I'm at it, how about how to easily remove the plastic lens cap on the exterior tear drop running lights?
Thanks, John
Jeanne and John, and always with us...Jake
2008 30' Classic Ltd Rear twin, 2014 Ford Super Duty
WBCCI 3100, unit 12, TAC USA-1, Escapees 129379
https://instagram.com/silvereagle3100/
SilverEagle6 is offline   Reply With Quote
Old 02-01-2015, 06:19 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Here's a photo careful pressure will release the lens.
On ours I just removed the screws and and worked a 2' length of fine stainless wire under the flange to cut the sealant, pried carefully and lifted out.
Old 02-01-2015, 08:46 AM   #3
2008 30' Classic
Thanks. There are no screws on the metal ring. Nor are there any screws in the lens. The metal ring does not screw on or off as best I can determine, but it does rotate.
Old 02-01-2015, 09:00 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Picture?
MICHAEL
Old 02-01-2015, 09:21 AM   #5
Question
Is this the one?
Looks like it does just twist off.....what direction? Left
Old 02-01-2015, 10:33 AM   #6
2008 30' Classic
Yes, that is it. It moves slightly left and right, but does not screw. I'm about ready to take a small screw driver and see if I can pop it off, or at least create enough space to slip a rag and work the ring off.
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
(2)...airsteam outside marquis signs..read.."international airstream" eBay Watch Airstreams on eBay 0 07-01-2012 03:20 PM
Inside/Outside Speaker Question - 2008 Bambi 10" Ocean Breeze JerryMcMunn Audio, Video & TV 11 02-07-2011 11:31 PM
