Old 01-07-2011, 05:58 PM   #1
DougZ's Avatar
1972 27' Overlander
Venice , Florida
Outside light replacement
How do you change the spotlight fixture near the door on a 1972 Overlander? It has the chrome ring and looks to be held in by solid rivets. I hope I don't have to unrivet and remove the interior panels because they are in very nice shape and I would probably mess them up if I try to take them out.
DougZ is offline   Reply With Quote
Old 01-07-2011, 06:11 PM   #2
x
XXXX , XXXX
Doug is this the light you are talking about. It should be attached with 6 phillips screws.
If this pic ture doesn't work here is a link to the part.
Flood/Spot light 500092 [500092] - $24.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
wasagachris is offline   Reply With Quote
Old 01-07-2011, 07:22 PM   #3
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
Even if it is riveted, you should be able to drill them out from the outside and replace them. That is the point of blind rivets.
FLYNCLD is offline   Reply With Quote
Old 01-08-2011, 06:55 PM   #4
DougZ's Avatar
1972 27' Overlander
Venice , Florida
That is the correct light. The rivets are solid head and not hollow like the interior rivets. To replace with the same type of rivet, I would have to remove the interior panel, correct? I wouldn't mind going with stainless screws. I do have to replace it though - it looks really gnarley!
Old 01-08-2011, 07:57 PM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Doug - the rivets holding the light are likely Olympic rivets that have had the heads shaved - pretty fancy effort on someone's part for a light. They can be drilled out from the outside. Either center punch them to give your bit something to bite into or get one of these:
Rivet Removal Tool
Once you have the light installed seal the edge with Parbond. It will wick into the seam so it may take two coats to fully seal the gap.
http://www.vintagetrailersupply.com/...lants_s/24.htm
Overhead Light Switch "HI-LIGHT-LO" motilley Lights - Interior & Exterior 14 08-23-2017 06:11 AM
How to Light the Pilot in the Oven lcurrie Stoves, Ovens & Microwaves 3 08-01-2011 07:16 PM
Water Heater Pilot won't light giffy58 Water Heaters, Filters & Pumps 9 03-10-2011 06:56 AM
window operator replacement options GR8DANE Windows & Screens 17 01-10-2011 09:09 AM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
