Old 10-14-2019, 08:13 PM   #1
WIZ
2006 28' International CCD
Burlington , Ontario
Outdoor light above entry door not working
On our 2006 International 28 ft. light above entrance is not working. I found the socket a bit rusty. Replaced burnt bulb but still not working. Found 6 volt in the socket. Any suggestions to do troubleshooting would be greatly appreciated.
WIZ is offline   Reply With Quote
Old 10-15-2019, 12:49 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I would assume that this is a 12V fixture, so if you are only getting 6V, then you must have a very resistive connection. So step 1, I would disconnect the wires from the light fixture and measure the voltage on the bare wires. If you get 12V, then the fixture itself is causing the resistance. If still only 6V, I would pull the switch and check the voltage coming into it, and leaving it. You may determine that the switch itself is causing the voltage drop, or maybe you only have 6V coming into the switch, which means working your way back to the next junction. A wiring diagram would be useful at this point.
good luck!
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 11:04 AM
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 4 04-03-2016 10:16 PM
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 07:07 PM
Entry Ceiling Light Not Working, '07 Classic. GCinSC Lights - Interior & Exterior 6 03-21-2010 07:55 PM
Light above entry door silver buffalo Airstream Motorhome Forums 3 05-06-2004 08:40 PM
