Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 02-17-2008, 09:43 PM   #1
gmehal
Profile:  beaverton , Oregon
Only half of running lights working
We have a 65 31ft soverign, only half of the runing lights are currently working. The front 3 and front corners will not work but all others work fine. I pulled them all out and wires seem to be in good condition. Does anyone have thoughts on how to trace the source wire for the power for the front portion of the trailer? The lights all seem to be somewhat daisychained together, help I am losing my MIND!
gmehal is offline   Reply With Quote
Old 02-17-2008, 10:48 PM   #2
NevadaGeo
Profile:  1978 31' Excella 500
Genoa , Nevada
Check your umbilical connection at the front of the trailer, it'll look good but not good contact. That age might also have a worked over older 6 prong into 7 prong plug at the newer tow vehicle that gets wishy. (Been there, done that.) Got the umbilical plug fixed up and those other running lights started to work, majic.
NevadaGeo is offline   Reply With Quote
Old 02-18-2008, 12:12 AM   #3
ajanib
Steven and Susan
ajanib's Avatar
Profile:  1979 Argosy Minuet 7.3 Metre
Carmel , California
Also, pull your bulbs out and scrub the contacts well with emory cloth or fine sand paper. They get corroded easily.
ajanib is offline   Reply With Quote
Old 02-18-2008, 08:18 AM   #4
soldiermedic
Commercial Vendor
soldiermedic's Avatar
Profile:  1975 29' Ambassador
1953 21' Flying Cloud
O'fallon , Missouri
Welcome to the forum.
I had a smiliar issue with my old 56 Caravanner. You could have a short in your system. Have you recently installed anything new in your Airstream? The PO of the Caravanner had placed screws into the wall the barely pinched a wire shorting it.
I assume you checked the bulbs for burn out
Steve
soldiermedic is offline   Reply With Quote
Old 02-18-2008, 09:39 AM   #5
Darol Ingalls
Darol Ingalls's Avatar
Profile:
Remove the lense and check with a voltmeter or 12v test light. There is only one wire to each light. It comes through the base. Touch one test lead to it and one to the aluminum skin. Check all 5 lights this way. If you get no reading (or test light) the problem is somewhere else. The front clearance lights are wired seperately from the rear. There is a junction box somewhere in the front of your trailer. If it's '68 or older, there is a "patch" under the right front corner of the underbelly that covers the connection to the tow vehicle cord. If it's '69 or newer, the junction box is usually in the front wall underneath the couch. In all cases the green wire is for clearance lights. I suspect there is a loose wire in this junction box. Darol
Darol Ingalls is offline   Reply With Quote
Old 02-18-2008, 09:49 AM   #6
garyk1970
your airstream brother
garyk1970's Avatar
Profile:  1967 30' Sovereign
millen , Georgia
the park wire runs around the trailer,if the wire breaks,all the lights after the break stops working.mine was at the pass wheels (rat?) eat the wire in two....hard to do,but follow the wire along testing for voltage....
1967 airstream 31'soveriegn land yacht
temporally insanity caused me to polish it.
chrome wheels, balanced hd tires
TOW VEHC 02 TAHOE 5.3 4X4 AIR REAR SUSPENSION
garyk1970 is offline   Reply With Quote
Old 02-18-2008, 10:03 AM   #7
Darol Ingalls
Profile:
Just re-read your post and realized your trailer is a '65. Remove the underbelly patch (probably just ahead of the step) and you'll find a rat's nest of wires connected with wire nuts. Sort out the colors. There should be two green wires: one for the front clearance lights and one for the rear clearance lights and tail lights. You'll probably find all sorts of dirt, shredded insulation, and who knows what else in there! Darol
Old 02-18-2008, 05:03 PM   #8
eubank
Lynn
Commercial Vendor
eubank's Avatar
Angel Fire , New Mexico
Here are a couple of earlier threads that may be of help:
67 safari no front running lights
No running lights; Lynn green-faced!!!
Lynn
WBCCI 21043
Lynn's blogsite: http://forum.aardvarkrv.com/blog/
If you're WBCCI, come visit us at the park (and get more cool air and less oxygen and ... a 50% discount!)
Old 02-19-2008, 10:35 PM   #9
gmehal
Wow thanks for the informative replies. I will look over these areas over the next few days and try and find the junction box. There is a junction box cover next to the door side towards the front that I will check, if that's not it I am going under! Will report back as to my findings.
Also it would seem that the lights would be daisy chained one to the other in sequence, my front ones in some cases have 2 wires linking each one together, more than seems necessary and the wire is a newer looking darker more flexable green. Wonder if the PO did some hacking?
Thanks again everyone
Old 03-01-2008, 05:59 PM   #10
gmehal
figured it out folks, sure enouh the green wires that run down the front inner skin passed through a hole in the wood floor. When I ripped out the roted wood floor in the front and pulled it out it ripped the wires in two. found them after some digging around and were barely visable. Haven't tried hooking them back up yet but I am sure this is the problem.
Thanks all for your help
Old 03-18-2008, 06:51 PM   #11
Arizona Guys
Profile:  1996 34' Excella
scottsdale , Arizona
I have a similar problem with my 1996 34 Excella and need help, except I have no running lights at all. Back up, signal, brake lights all okay. Tried trailer plug on two different tow plugs, so know it is not the tow vechicle. Any easy way to test the trailer plug to see if problem is there. Did replace a side running light which was not working but connected white to white and black to black with "new butt connetors". Hate to spent big $ for something that might be simple.
Arizona Guys is offline   Reply With Quote
Old 03-19-2008, 06:34 AM   #12
Jim Clark
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
I had the same problem on a 2005, the branch circuit which fed the front lights had disconnected. If all the lights are out then I would verify no power to them then look for the connection from the power bus or wiring harness. More than likely they are all wired together in parallel so if one burns out the rest will stay on, as always check your grounds. Don't lose your mind just start tracing wires, get a good flashlight and take your time you will be surprised at how much you will learn and the knowledge will come back to help you when you least expect it. I may even want to take a few notes and add to your trailer note book.
Look on the bright side if you have to have running lights out I feel it is better to have the fronts out than the back. I traveled about 500 miles at night with mine out.
Glad you found the problem, I should have read the entire thread.
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim,
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 07-04-2008, 10:57 PM   #13
TCHANNEL
Profile:  1967 26' Overlander
SIMPSONVILLE , South Carolina
Running light question
Hey I have the same problem with my 67 Overlander. How is the green wire for the front running lights routed, that is, where do I look to find the lead so I came chase the problem. My interior panels have not been removed. I only have one green lead connecting to my pig-tail.
Thanks, Tim
TCHANNEL is offline   Reply With Quote
no 12 volt lights working marifn Lights - Interior & Exterior 9 12-12-2007 07:40 PM
Tail, running, clearance lights not working dufferin Lights - Interior & Exterior 14 07-09-2007 02:53 PM
Running Lights cameront120 Lights - Interior & Exterior 4 03-23-2006 10:23 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 09:54 AM
Running Lights Barkingspider Lights - Interior & Exterior 7 12-11-2003 09:48 PM
