Old 02-02-2015, 06:47 AM   #1
1954 22' Flying Cloud
1967 24' Tradewind
manerba del garda , Italy
old electric wires
Hello, I'm restoring my 1959 Streamline I wouldn't take inner skins apart replacing old electric wires. I thougth getting the old wires like a pulling guide knoting new ones' to the end. This way is not good because olds' seem to be glue inside the wall, they don't flow out. Any idea for my goal?
Thanks everyone Luca
luca16 is offline   Reply With Quote
Old 02-02-2015, 07:30 AM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I've taken apart an early 1970's model Airstream including removing the interior skins and if your unit is put together similarly as that 1970, you will never be able to snake new wires using the old ones as fish wires. The existing wires are attached in many places to the interior ribs with cable ties, and the like. The only way to replace the wires is to remove the interior skin or surface mount the new wires in as inconspicuous places as you can.
Sorry to be the bearer of bad news on this.
Bob Martel
WBCCI# 5766
Old 02-02-2015, 08:09 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Drill out the interior wall panel rivets below, or above, the windows. The interior panel can be moved away from the formers ....enough to put in new wiring. You have to make holes, and rubber grommet them, thru the formers as you run the wire. Then re-rivet (or screw) the interior panel back in place. This not the correct way, which is to completely remove the panels and run the wires. But it will work for you.
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 03:02 PM
Old, old, old airconditioner removal bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-17-2012 04:19 PM
For electric for genration hase to be oun for electric RichardT Electrical - Systems, Generators, Batteries & Solar 7 12-05-2005 08:05 PM
I had a fun day (pictures) Old trailers and old stuff RichardT Off Topic Forum 11 03-13-2005 03:49 AM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
