Old 07-20-2015, 11:20 PM   #1
iwbull's Avatar
1965 17' Caravel
San Francisco , California
Odd LED light issue -Help
I have a 65 Caravel with the original light fixtures. I have replaced the original Univolt converter with a modern power converter. The issue I am having is with the LED lights I purchased to replace the incandescent 1141 bulbs. These LEDs work in all but two fixtures.
One is the double reading light over the street-side bed, one works the other does not.
The others fixture is the 4 bulb light over the galley.
All of the LED bulbs are functioning and work in all the other fixtures. Also the incandescent bulbs work fine in the two problematic fixtures.
Any ideas on what the problem may be?
Any help is appreciated.
Ingall Bull
1965 Airstream Caravel
2014 Jeep Cherokee Latitude
V6, Tow Group, Comfort and Convenience Group
o)))))))o
iwbull is offline   Reply With Quote
Old 07-20-2015, 11:38 PM   #2
1979 23' Safari
Wayland , New York
Could be polarity in the sockets. Some LEDs are polarity sensitive, incandescent aren't, so if the non working sockets are wired backwards it can keep the LEDs from working.
Old 07-21-2015, 07:52 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
Some of the light fixtures on our 63 Safari had two bulbs in each, a 120vAC and a 12vDC.
Old 07-21-2015, 07:09 PM   #4
iwbull's Avatar
1965 17' Caravel
Thanks. That may be it. Do you know the correct polarity for those single contact sockets? Is the bayonet (-) or (+)
Ingall Bull
o)))))))o
Old 07-21-2015, 07:29 PM   #5
MaineStreamer's Avatar
2007 20' Safari
Old Orchard Beach , Maine
Fuse?
Marty Womer
Old Orchard Beach, Maine
MaineStreamer is offline   Reply With Quote
Old 07-21-2015, 07:35 PM   #6
1979 23' Safari
Wayland , New York
The center post is positive, the housing is negative. Multimeter will show negative voltage if wired backward. Just make sure you have the leads straight(+&-). May want to check as mentioned some early trailers had a mix of 12v and 120v lights, but if 12v bulbs worked in them they should be 12v otherwise would have blown instantly.
Old 07-21-2015, 10:18 PM   #7
iwbull's Avatar
1965 17' Caravel
Thanks. It's all 12v. Only plugs are 120v in the Caravel.
Ingall Bull
o)))))))o
Old 07-22-2015, 02:16 PM   #8
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
Have you swapped the non-working LED's into other fixtures? maybe the LED's themselves are bad?
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 07-22-2015, 02:29 PM   #9
2000 30' Excella
Monticello , Florida
When I had the same problem it turned out to be the circuit breaker...open the box and look at the small buttons off to the side of the bus bar. I didn't know they even there!
07007 is offline   Reply With Quote
Old 07-22-2015, 11:46 PM   #10
gecko's Avatar
2009 28' International
Pacific Palisades , California
It's most likely bad LED units or incorrect polarity. In our 28' International, I swapped out all of the halogens for LED's and had problems with two different light fixtures. In one case, the leads on one LED "bulb" were first backwards and inverting the bulb took care of it, but ultimately one if the heads was slightly misaligned and after inconsistent performance, I trashed it and replaced it. No problems for three years now. The other is a 20 LED bathroom fixture and one LED flickers annoyingly and intermittently. I will replace that one soon, too.
As the other party suggested, have you been able to get a different LED to work in the socket in question? And have you tried turning it 180 and reinserting to check polarity?
gecko is offline   Reply With Quote
Old 07-25-2015, 12:48 PM   #11
Dan@LED4RV's Avatar
Denton , North Carolina
polarity
If HiJoeSilver is right, and I think he is, all you need to do is take down the fixture and switch the two wires. That will change the polarity.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Odd electrical ground / neutral issue on '89 370 classic romakdaddy Classic Motorhomes 29 10-23-2013 06:44 PM
1973 Safari odd rear exterior lights issue DonnyK Lights - Interior & Exterior 9 10-22-2013 11:02 AM
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 10:55 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 12:03 PM
