Old 07-08-2009, 06:57 PM   #1
1968 26' Overlander
Durham , North Carolina
No running lights or tail lights...
Hi all,
When I towed my 1968 AS home a couple of weeks ago all the exterior lights worked, IE: L/R turn signals, running lights, brake lights and tail lights. Today I was checking to see if any of the bulbs need replacing and discovered that the running lights and tail lights are no longer working. The turn signal and brake lights are working properly. I don't think I did anything to effect the lights, but who know, maybe in my fumbling around maybe I did cause a problem.
I don't think it is the bulbs since 1) they were all recently working and 2) the brake and turn siginal lights work.
Anyone have any thoughts or suggestions as to what the problem could be.
Thanks for your help.
Pete
goswick is offline   Reply With Quote
Old 07-08-2009, 07:14 PM   #2
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
Check the fuse on your tow vehicle, and the trailer to TV connecter. Adios,John
Diesel1 is offline   Reply With Quote
Old 07-08-2009, 07:20 PM   #3
1968 26' Overlander
All the lights on the TV work as they are supposed to, so I would think that would rule out a fuse as the problem.
The connection between the TV and AS looks good as well. As I said, everything was working a week or so ago so I don't "think" it is the connection.
Thanks...
Old 07-08-2009, 07:27 PM   #4
Diesel1's Avatar
1967 24' Tradewind
Depending on how new your TV is it will have a seperate fuse for your trailer lights. On my seven pin conecter the TV portion gets dirty and I sometimes lose a circuit till I manually clean the connecter. My 1995 F350 has seperate fuses & relays for all circuits on the 7 pin connecter. Adios, John
Old 07-08-2009, 07:33 PM   #5
1972 25' Tradewind
Madison , Wisconsin
First check to see if there is power at the socket. Those lights are chassis ground. Remove the bulb and check it with the meter---make sure the meter is set for DC (past experience from a good friend--another story!).
If nothing seems to work, try this---be careful as any ground you make will blow the 20amp fuse---in fact have a couple of extra fuses handy. Run a jumper with an alligator clip from your fuse box (circuit side of the fuse clip--)so you have a known 12v power source right by the lights. This way you can test circuit continuity and ground. Be sure to disconnect the circuit wires before using power from the jumper. Once you are set up connect the jumper to the hot side of the socket--the light should come on. If it doesn't test the light using the jumper and a second jumper connected to the AS skin/frame or any grounded part. If the light works you may just have some corroded sockets.
It may just be a case of old corroded sockets. That was part of a problem I had. I ended up just replacing the lights and sockets with LED sets and sealing them in.
I had a rear running light that would not power up no matter what I did. The amber rear curb side running light was also dead (same circuit). I ran a jumper from the middle running light to the side that did not work, now both are operating just fine. There was obviously a defect in the wire between the running lights since that circuit is a ground return.
If every thing still is dead
Be sure to put the jumper clip on the right circuit...(make sure the circuit fuse (20 amp)and the 12V feed fuse (30 amp?--I think) is good. If all other 12v are working it is not the main fuse. While I think of it, change the circuit fuse with one of the other fuses and see if there is still a problem. It only happened once to me but I did have a 20 amp fuse that looked perfectly good that was a dud.
Just a theory of mine but I try to avoid towing in the rain. I have noticed a lot more corrosion on rear lights than anywhere else--not just on AS...pretty much all brands. I suspect the vacuum caused by towing sucks some water in and eventually causes corrosion...of course there are a number of other things that cause the same problem.
Good thing we have an edit button....Diesel1's response reminded me...it would be best if you disconnected the tow vehicle during the tests I describe or you could blow fuses in the tow vehicle--this I know from first hand experience. What I am describing is just testing the circuit in question...tow vehicle connections is a different set of tests.
Smokin Camel is offline   Reply With Quote
Old 07-08-2009, 07:54 PM   #6
1968 26' Overlander
I will check to see if the TV has a fuse for the trailer lights. It is a 1996 Dodge Ram 1500 and only had a 4-pin connector. I had a 7-pin and brake controller added before I got the AS. I guess it is possible that the 4-pin connector has a fuse in the TV and it is blown. Will look into that tomorrow.
Thanks.
Old 07-08-2009, 08:31 PM   #7
floridartist's Avatar
1973 29' Ambassador
Fort White , Florida
Just a thought, on my 73, all the lights were wacked out, I never thought I would find the problem, it was my old 1973 truck to rv connector all along.
today I took the thing apart, did some tighting up, then took a drumel tool with a chain saw sharping bit and gently brightened up all the sockets, just plugged it in and , glory to be, everything works. now Id like to find out what to spray into the sockets to protect them from corrosion, any ideas? good luck with your streamer, John
floridartist is offline   Reply With Quote
Old 07-08-2009, 08:41 PM   #8
Silicone spray and more silicone spray. It's impossible to put to much on the connectors.
Use the same stuff on new window and door gaskets which will extend their life.
Old 10-16-2009, 07:33 PM   #9
ryan3326's Avatar
1976 31' Sovereign
Columbus , Indiana
exact same thing happened to me tonight. I will check to see if my TV (2004 Nissan Titan) has a seperate fuse for the running lights.
Thanks.
In Search of "Hill Country"
www.doublesanddogs.com
ryan3326 is offline   Reply With Quote
Old 10-17-2009, 06:42 AM   #10
Lothlorian's Avatar
Loganville , Georgia
I had the exact same problem with the running lights two different times. The first time it was one of the pins on my truck connector. It got pushed back so it was not connecting with the connector on the cord that goes from the truck to the trailer. I used a needle nose pliers and pulled it back into position. The second time it was a wire on the Cord that came loose from the pin on the cord that connects to the trailer. It was still attached but very loose. It was tightend down and now it works great.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 10-17-2009, 08:06 AM   #11
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
Was at the Dodge dealer having the emergency break repaired and all my fluids changed out ... got to talking trucks with an old boy in the waiting room ... he is an auto worker here in town and he assembles trucks. When I told him about my random "lamp out" warning light and said that I would probably have to WD-40 all my lights he just looked at me and said "Lithium grease." I must have had a stupid expression on my face because he went on to say "You know, that white stuff you spray on your door latches ..." I knew what he was talking about and asked "Doesn't it short out?" He goes "Nope. You'll have no more problems ... did my whole truck." I haven't tested this yet but will probably do one tail light assembly to see first.
Xbob2 is offline   Reply With Quote
Old 10-17-2009, 08:46 AM   #12
WD-40 is basically a cleaner that can be used for electrical terminals.
For long term terminal protection use "silicone spray."
The white lithium grease is good, but messy. I use it on my garage door hinges.
Old 10-17-2009, 09:12 AM   #13
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
No Lights
Pete,
Don't forget to check where the umbilical cable attaches inside the trailer. Some times one of the nuts will back off causing intermittent lights.
Like others I clean the connectors regularly. I prefer the LPS products, such as LPS ElectroClean for cleaning and the LPS heavy duty silicone to lube.
Also run you hand along the umbilical cable to be sure it has not possibly dragged the asphalt and scraped through one of the wires or check for any crimps where the wire may have been pinched during a sharp turn.
fltlevel510 is offline   Reply With Quote
Old 10-17-2009, 12:19 PM   #14
Ottawa , ON
Caig DeoxIt D5. Cleans and protects, made specifically for electrical connections.
Works wonders on dirty switches, too.
ďCourage is being scared to death, but saddling up anyway.Ē
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
Tail, running, clearance lights not working dufferin Lights - Interior & Exterior 14 07-09-2007 01:53 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
Wiring tail & running lights JimC Electrical - Systems, Generators, Batteries & Solar 4 04-14-2003 12:38 PM
