Old 10-18-2009, 07:23 AM   #15
floridartist's Avatar
1973 29' Ambassador
Fort White , Florida
I went down here to a trailer place and had them check the connector, they were very good at what they did, got me all set up with the running lights and the brakes, its very comforting and important that everything is working right, they also recommended that I just wire in the whole pigtail to the Airstream permanently, it makes perfect sense to me, that way I wont have to worry about the connectors getting worn out and loose in time.
John123
floridartist is offline   Reply With Quote
Old 10-18-2009, 09:05 AM   #16
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
It's possible that you have the same issue we had with the 67: The connection between the long "pigtail" that leads to the tow vehicle and the native wiring. We fought at off-and-on battle with running lights and tail lights (but not brake and signal lights) for several years, and lost continually. Finally, with help from folks here, I found the connection. There's a little hatch door, probably screwed or riveted in, on the bottom of the rig toward the right front. Remove it and check all connections. (If memory serves me right, that circuit is the green one.)
Lynn
WBCCI 21043
Old 02-19-2010, 07:18 PM   #17
1973 29' Ambassador
This has been a very informative thread, after having the repair shop set up my Airstream lights, everything worked fine, after a good trip camping last summer, all lights worked, then the next trip, back to the same problem, no, blinkers, one brake light worked, no running lights. I,m back to the drawing board. then I hooked up my cargo trailer in which everything worked fine for years, well thats all messed up, perhaps there is now a short in my truck, oh boy.
John
Old 02-19-2010, 08:41 PM   #18
richinny's Avatar
2011 34' Classic
check the wiring at the plug of the tow vehicle.
Ricky
Old 02-20-2010, 07:53 AM   #19
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Ugggg
Lynn
I had allowed myself to forget my running light problem . I can (or could last time I checked) jump wires at the pigtail and get lights- just not with the light switch. Its interesting that so many of us have the same issue of the running lights falling out while the turns and brakes do not. Its a PITA not being able to tow after dark or in the rain.
Lynn, I didn't even know about that hatch. Do all have them? One more thing to remember to fix.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-20-2010, 08:21 AM   #20
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
I'm not sure if all of them have the hatch in that particular location, but it must be near the front someplace. The big wire bundle, wrapped in rubber/plastic and leading to the truck, must attach someplace to the native wiring of the trailer. This bundle is sold as a unit, so to speak, with one end terminating in a plug, and the other ending with a wad of individual wires sticking out. It's the end where it connects to the trailer that seems to be a source of these problems.
But not that surprising, if you think about it. The connections have been down there, getting wet from time to time, for the last 30-40 years. I probably need to go down and check another of them, because I have the funny-fuzzy feeling that the charge wire is not doing its job to charge up the trailer battery while underway.
Oh, and Rodney, we owned the trailer for nearly ten years before I discovered the hatch, and that was only because somebody else here in Airforums told me to get down on the ground and look!
Lynn
WBCCI 21043
Old 02-20-2010, 04:59 PM   #21
1973 29' Ambassador
Thank you for the reply, I did a little investigating I used another vehical to see if I had the same problem with the airstream lights and my cargo trailer lights, and my results, yes both showed the same problem, that rules out a problem with my truck. I am happy about that.
Now as for the Airstream, being I changed out all the running lights with LED, perhaps its time to change out the old tail lights with LED as this will rule out another area of the possible glitch.
My question would be, The big blue wire going into the converter, is that not just for keeping the battery charged while its hooked up to my truck, if all my fuses look good, where else could I check for a good or bad connection for my tail lights.
Thanks everyone
John
Old 02-21-2010, 04:59 PM   #22
1973 29' Ambassador
with a $20 investigation, everything works right up to my 7 way connector on my TV, so tomorrow morning its off to the Ford Parts dealer, I just wonder what blew it out. do you think the Airstream univolt could have had anything to do with it.
Thank you
John
Old 02-27-2010, 08:56 AM   #23
1973 29' Ambassador
Ok, since all five of my trailers have the same tail light problem, one would think it was my truck that is the source of the problem, so first I took my truck to the Ford dealer, nothing wrong with my truck, then I took my truck with my cargo trailer to Texas Trailers, still, no problem with my truck, but they found the problem, it was the ground at the tail gate of my trailer, seems that the hinges were rusted out and lost the ground contact, they put a wire from the frame to the tailgate, problem solved. So my question for my Airstream is as follows?
Where would I attach a good ground wire from where?and then run the ground wire to the frame to make a good ground connection on my Airstream, this might solve all my running light problems.
Old 02-27-2010, 09:30 AM   #24
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
Run a temp ( jumper) ground wire from truck frame to trailer frame. Then if that fixes your problem start repairing your ground problem. Adios, John
Diesel1 is offline   Reply With Quote
Old 02-27-2010, 09:31 AM   #25
The trailer already has a ground wire in place.
The color of that wire is white.
Also, it's the largest terminal that you see in the trailer connector.
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
Tail, running, clearance lights not working dufferin Lights - Interior & Exterior 14 07-09-2007 01:53 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
Wiring tail & running lights JimC Electrical - Systems, Generators, Batteries & Solar 4 04-14-2003 12:38 PM
