Old 07-29-2009, 07:27 PM   #1
1962 19' Globetrotter
Jamestown , Rhode Island
no running lights
SO FRUSTRATED!!: We have a '62 globetrotter and a 2003 Sprinter van. We have towed successfully for several years but haven't used the trailer for a year.
We have cleaned all wires and sockets, tested the tv and the trailer with a battery and with an idiot light. There is continuity in all pigtail wires, and all lights and turn signals work when tested from the block but when we connect the running lights don't work. The umbilical and plug are new.
We are trying to leave soon-can anyone suggest a possible solution to this problem?
dougnjano is offline   Reply With Quote
Old 07-29-2009, 07:46 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It's possible the circuit board in the Sprinter has failed.
Old 07-29-2009, 08:00 PM   #3
The running lights on the Sprinter work, just not on the AS when connected-could this still be a Sprinter problem?
Old 07-29-2009, 08:02 PM   #4
Well Preserved
1993 21' Sovereign
IIRC, there is a circuit board in the van that operates the trailer lights.
Old 07-29-2009, 08:06 PM   #5
we tested the pins on the plug with the idiot light and they all worked but I will check the circuit board tomorrow thanks
Old 07-29-2009, 08:19 PM   #6
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
Are your othe lights working? Do they work correctly? What I'm thinking is a possible bad ground.I worked as a electrical automotive tech for 15 years and the most common problem on dc electrical was the ground.
arodriguez60 is offline   Reply With Quote
Old 07-29-2009, 08:23 PM   #7
Well Preserved
1993 21' Sovereign
A quick check for that would be to temporarily connect a wire from the trailer tongue to the frame of the truck. If everything works, it's a bad ground.
Old 07-29-2009, 08:31 PM   #8
thanks we'll try that in the am!!
Old 07-30-2009, 01:16 AM   #9
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
We had problems with ours on the trip we are on right now. It turned out to be a bad/loose (7 blade side connector) plug on the trailer in front where the wiring plugs into the trailer from the TV. It being almost 40 years old was just warn out I guess. For now we taped it to better secure it until we can get home and replace it. Got a new one at Walmart to install.
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 07-30-2009, 07:26 AM   #10
yes but all of that is brand new-we even bought another new one yesterday-still no fix. we'll look at the truck circuit today and see if that's it
Old 07-30-2009, 12:04 PM   #11
Terry's trick worked-it is a bad ground!
Old 08-01-2009, 07:21 PM   #12
how do we fix a bad ground?
Old 08-01-2009, 07:46 PM   #13
1969 25' Tradewind
1983 34' Limited
Images: 85
Check to see where the white wire from the 7 pin connecter goes on the TT. clean the connection (sandpaper , knife your test light whatever) where it is connected could also be loose. On some trailers I've seen the ground right at the tongue.
Old 08-02-2009, 07:21 AM   #14
I just want to thank all of you who took the time to post and help us with our wiring problem-we are all fixed and ready to roll-thanks a million-you all are the greatest!!!
Running lights nilesrob Lights - Interior & Exterior 16 10-09-2010 06:36 PM
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
Running Lights Joe Z Lights - Interior & Exterior 7 12-11-2003 08:48 PM
running lights mazda997 Electrical - Systems, Generators, Batteries & Solar 0 08-27-2003 08:55 PM
