Old 10-24-2016, 02:08 PM   #1
ewbradshaw's Avatar
2008 27' International FB
Sioux Falls , South Dakota
No running lights
Brake and signals work fine. Can anyone tell me what to look for?
2008 Int 27FB.
ewbradshaw is offline   Reply With Quote
Old 10-24-2016, 02:12 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
With the parking lights on with a volt meter or test light check the 11 o clock tab in the receptacle on the TV. If no voltage there the problem is in the TV.
If voltage there check the brown wire at the trailer end of the umbilical cord where it enters the trailer. If none there the problem in in the plug or cord.
2004 Excursion 4x4
Old 10-24-2016, 02:32 PM   #3
ewbradshaw's Avatar
Great! Thanks. Electricity is not one my strong points.
Old 10-24-2016, 04:14 PM   #4
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
If you are lucky, the problem will be as simple as I encountered two weeks ago when taking our trailer out.
Hooked it up, brake lights working, turn signals working, no running lights.
Unplugged the cable from the truck, plugged it in and out a couple of times - back in again all lights working! Poor connection in the plug! Always a good thing to check first!
If the contacts in the plug / socket look corroded or dirty you can often brighten them up a bit with a small needle file or similar, (being careful not to short anything!) Then a dab of dielectric grease could help as preventative mtce.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 10-25-2016, 12:21 PM   #5
ewbradshaw's Avatar
Thanks for the advice!
Urgent Help....No Brake Lights when running lights are on Debnw Lights - Interior & Exterior 10 05-08-2015 03:04 PM
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
1976 Argosy 28 Brake lights, turn signals, running lights not working!!! Argosy1976 Batteries, Univolts, Converters & Inverters 6 06-22-2012 05:20 AM
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
