Old 08-03-2010, 02:31 PM   #1
1978 31' Excella 500
SOUTH ANHERST , Ohio
No power blown fuse
I have a 1975 argosy and the following all worked and now do not ????????? They are as follows the
range hood fan
light over the sink
galley fan
fresh water pump
light in bed room
i think all these are on the same circuit and i have a blown fuse -but were ---need help looked every were !!!!!!!
All the other lights work ????
I think it is a blown fuse , but can not find the fuse panel in this 1975 argosy ?????? Any ideas ????
Gosman is offline   Reply With Quote
Old 08-03-2010, 03:00 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
The fuse panel should be at the converter.
Garry
Old 08-07-2010, 10:06 AM   #3
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
The Univolt converter is a rectangular blue box. Mine is located in the bathroom closet under a panel. I have four fuses in mine for four different circuits. Could be a blown fuse but in mine I also found that due to vibration the fuse holders can get loose and the fuse doesn't make a good connection. If it looks good when you pull it out or meters good then the fuse holder itself can be the issue.
RichHog is offline   Reply With Quote
Old 08-07-2010, 12:51 PM   #4
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
I had troubles like that years ago and finally ripped the fuse box out and replaced it with a board that took the spade-type fuses: problems solved.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-04-2010, 10:53 PM   #5
Riverside , Iowa
We have a 1976 soverign that the same things worked, thought the battery was dead, recharged it and found out that by testing that the number three circuit has a short in it, how do you find out where it would be
Jean Wisjink is offline   Reply With Quote
Old 10-05-2010, 07:31 AM   #6
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
RichHog - I had the same loose issues.
Gosman - There are several connections
that can cause such a general outage. The
converter is on the floor, so get a droplight
and lay down(get confortable) and check them
all. A clipboard for notes and drawing is also usefull.
You can bypass a fuse with a simple jumper wire - for testing.
Oh yes...a single loose/corroded ground connection can
also cause such general outages.
Go slow and clean and tighten everything while you are doing this.
It is a PAIN and you do not want to do it twice :-)
every connection
kennethowens is offline   Reply With Quote
Old 10-05-2010, 09:18 AM   #7
jimmickle's Avatar
2000 31' Land Yacht
For finding a short, get a shortfnder from JC Whitney.
Your Search Results - JCWhitney
jimmickle is offline   Reply With Quote
Old 10-06-2010, 07:46 AM   #8
Riverside , Iowa
I did some more checking with the fuse and found the fuse ( 50 ) had a bad inside wire, replaced that, now have power with battery charger hooker up. I think I have some other problems like bad battery and mice in the univolt charger. I am going to pull the cover off and see if they chewed some wires inside, what voltage should I have coming out of it? I checked the two small wires that have small fuses on them with the meeter that I have and also with a test light.
power jack keeps blowing fuse? jlemmons Jacks, Stabilizers, Lifting and Leveling 6 08-01-2009 10:38 AM
12 volt inline fuse stops power??? tinbender Vintage Kin 6 07-09-2008 04:37 AM
Blown fuse toastie Batteries, Univolts, Converters & Inverters 7 09-05-2007 07:07 PM
Marker lights blown fuse Paul Daugherty Classic Motorhomes 0 09-07-2005 08:28 PM
Power converter "fuse" rfield54 1997 - 2004 Bambi 0 09-02-2003 02:26 PM
