Old 05-01-2013, 08:47 PM   #1
Airstream fanatic
Grapes's Avatar
Bouse , Arizona
no lights at all exterior
Hello,
So we just got our truck. The PO gave us a connection to hook up the AS to the truck. The lights work just fine on the truck when it is plugged in, but none of the lights work on the AS.
All the light bulbs are good, and we have the trailer connection in right. So why are the lights not working?? Can anyone help?
Does the battery have to be in the box? We took it out to clean the connectors. We thought to unplug the AS from the main electrical outlet, thinking that was the problem. But it wasn't.
Any solutions for us? Thanks a bunch!
Cass
1979 Sovereign International (Olivia)
1986 F-250 4X4 (Oscar)
BLOG: http://grapesbigadventure.wordpress.com.
Grapes is offline   Reply With Quote
Old 05-01-2013, 09:01 PM   #2
Airstream fanatic
Grapes's Avatar
Bouse , Arizona
OK update... we got both break lights and both blinker lights to work... its just the running lights now. All hubby did was take off the covers and blow on them. The trailer had been sitting in the hot Arizona sun for 1 1/2 years... so there's dust and dirt
Any suggestions for the running lights or just basically pull them apart and clean them and hope to God they work? Lol
Cass
Old 05-01-2013, 09:49 PM   #3
1974 Argosy 20
Kooskia , Idaho
Along with the bulbs themselves, try plugging the umbilical cord in to the truck outlet, and unplugging it several times. It is common for the connections there to become dirty or corroded and just 4 or 5 in and outs of the plug in the outlet will wipe the contacts clean and they will work again. I often have to do this when my trailers and tow vehicle have been sitting for a few months. Sometimes only one thing will not work, like the running lights, or one stop/directional light, or even the brakes themselves, and everything else will be working. That causes some head scratching.
So, try that along with your other things.
Old 05-01-2013, 09:57 PM   #4
Hodum's Avatar
1995 34' Excella
Corinth , Mississippi
I encountered the same problem once and discovered that there was a fuse blown in my truck. It was labeled "trailer running lights," or the equivalent. Replaced the fuse and the problem was solved.
Why settle for anything less?
1995 34ft Classic Excella 1000
2012 Kings Ranch F-250 FX-4, 6.7 diesel, 6 speed auto trans.
TAC # MS-8
Hodum is offline   Reply With Quote
