Old 10-25-2014, 04:25 PM   #1
1968 20' Globetrotter
1988 29' Excella
Jonesboro , Georgia
No Exterior Lights
I have a 1988 29' Excella.
I put it up about twelve months ago with all lights working. Today I brought it out of storage to sale and had no lights, running, brake or turning.
Having restored a 68 Globetrotter I understand about mice etc.
But when I check the plug from the truck using the plug's ground, all lights work.
When I apply 12v to the trailer plug using the trailer plug's ground, all lights work.
I have even hard wired a wire from the truck frame to the trailer frame and no luck.
Honestly, I don't really know where to start. Suggestions?
68Glbtrotter is offline   Reply With Quote
Old 10-26-2014, 08:51 AM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Looks like you know your trailer wiring harness and umbilical cord are good judging from your experiment of applying 12v to the trailer plug pins. If I recall correctly, pin #1 is the ground. So applying your test battery negative to pin #1 and touching the other pins lights up the various running lights. If so, then you have verified your trailer's wiring and bulbs are good.
We need to verify your tow vehicle is delivering 12v to trailer. Your auto parts store may have a trailer plug test light you can plug into your tow vehicle and it will indicate all functions are working. Somehow you got to confirm your tow vehicle trailer plug receptacle if functioning. Does your neighbor have a trailer you can plug into?
David
Old 10-26-2014, 10:10 AM   #3
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Not an expert on the subject, but check the condition of the plug from your AS. Slip off the outer shield. I found a shorted wire which caused issues. Make sure all contacts are clean and tight. GL
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 10-26-2014, 10:14 AM   #4
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
What David said.
Troubleshooting logic says that if all the trailer lights are affected, the problem is most likely in the tow vehicle.
Old 10-28-2014, 06:44 PM   #5
1988 29' Excella
Jonesboro , Georgia
Thank you so much, for ideas. The parts store and driving to another trailer makes sense, simple solutions that are clouded when frustrated. That's my headscratcher- if both work with 12v and/or test light then which one is the culprit? I will verify truck first.
I've tried taking the plug apart but it will be more of a hassle than driving to my brother's. But it's coming I'm sure.
Dan
Old 03-30-2015, 02:04 PM   #6
tmeagle1's Avatar
1964 19' Globetrotter
Croswell , Michigan
I had problems with my truck plug getting corroded, starting fluid or electrical spray may help it on the tow vehicle. I bought some electric spray, sprayed it and let it dry, it did the trick.
Tim Eagle : Fiction
tmeagle1 is offline   Reply With Quote
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
LED conversion of exterior lights HowieE Electrical - Systems, Generators, Batteries & Solar 0 07-13-2006 05:07 PM
1986 345MH Exterior lights flash Classic Motorhomes 23 06-26-2006 12:21 PM
Should I? (adding exterior lights) bredlo Lights - Interior & Exterior 20 03-12-2004 06:48 AM
How do I test trailer exterior lights? Bryanhu Lights - Interior & Exterior 2 08-09-2003 06:27 AM
