Old 03-04-2010, 08:42 AM   #1
DD.KARAOKE's Avatar
1976 Argosy 20
Peralta , New Mexico
Images: 12
Lightbulb No Brake Lights On Trailer
Hello all, I just updated the 7 pole connector with a 7 blade, and installed the one on the TV. everything works except the brake lights on the trailer.
both turn signals work just no brake lights. OK I admit I'm a dumb a** when it comes to electrical, so any advise would be appreciated.
thanks
Dorian
AIRFORUMS # 44025
TAC # NM-2
TAC - We are dead-serious about having fun!
TAC's unofficial KARAOKE Provider
DD.KARAOKE is offline   Reply With Quote
Old 03-04-2010, 08:48 AM   #2
DD.KARAOKE's Avatar
1976 Argosy 20
Images: 12
sorry, I should mention the TV is 1994 Toyota 4Runner, and all the lights work properly.
AIRFORUMS # 44025
TAC # NM-2
Old 03-04-2010, 09:40 AM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Makes absolutely no sense to me,power to turn signals runs in the same wires as the brake lights,I doubt you have the separate fuses under the hood for trailer,as my Silverado does.I`ll just lay on the sidelines and maybe I can learn something. Dave
easyride is offline   Reply With Quote
Old 03-04-2010, 11:17 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Does your tow vehicle have separate stop (brake) lights and turn signal lights? If yes, then you need an adapter on the TV side to conver the separate stop and turn signals into the single wire for each side in the trailer.
Chris
Old 03-04-2010, 11:24 AM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Chris
Chris is correct. From the photos I located online, it looks like this is the case. There are amber lenses at the rear. Common on "foreign" designs.
Vaughan
Old 03-04-2010, 11:26 AM   #6
Minno's Avatar
1972 31' Sovereign
Then something like this should do the trick. They get wired into your TV.
Chris
HY-Power Diodes 2 Pk. - Item - Camping World
Old 03-04-2010, 11:59 AM   #7
DD.KARAOKE's Avatar
1976 Argosy 20
Images: 12
Sounds like that WILL do the trick, thanks
Dorian
AIRFORUMS # 44025
TAC # NM-2
Old 03-04-2010, 08:52 PM   #8
DD.KARAOKE's Avatar
1976 Argosy 20
Images: 12
Glad to report that the problem has been solved!
I picked up a "Taillight Converter" for $15.00 at "OReileys"
a local auto parts place, and it did the trick.
Now all the lights function as they should, now all I need is a brake control
and I'll be good to go.
Thanks for the advise.
Dorian
AIRFORUMS # 44025
TAC # NM-2
Old 03-05-2010, 01:43 AM   #9
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Brakes are always a plus
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Brake lights frscott Lights - Interior & Exterior 2 05-01-2009 07:50 PM
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
no brake lights libbysmom Airstream Motorhome Forums 5 05-22-2006 08:34 PM
Brake lights kooblekidz Airstream Motorhome Forums 1 02-04-2003 04:51 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 06:43 PM
